Thread: P01260 - last test failed.
Results 1 to 20 of 26
  1. #1 Re: P01260 - last test failed.
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Solved: Gt body is always high speed. Just had to turn off the error code.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: P01260 - last test failed.
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    So the gt fuel pump is always in run high mode
  3. #3 Re: P01260 - last test failed.
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Quote Originally Posted by 97gtp01gt99gt View Post
    Almost all cars were high-only. The FP speed control relay/resistor was a commonly deleted or bypassed system on 3800 SC cars to eliminate the possibility of failure.
    Total guess, but with a SC tune and LTFT's wanting to reduce fuel, it could've been trying to enter low-speed mode and erroring due to the hardware not being there. Never looked into how detailed they programmed that system, so apply much salt to my guessing on that. Probably something in that realm of the pcm thinking it should be seeing that FP resistor and speed relay, though. Kill the DTC in the tune, and party on, if you don't have a car that came with that stuff.
  4. #4 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    So would this code cause my car to idle at around 1500 rpms
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. zzp pcm failed so im swaping to a gtp pcm
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2012, 01:46 PM
  3. Failed emission test again.
    By jokyfo in forum General Tech Discussion
    Last Post: 12-12-2010, 11:00 AM
  4. failed lim gaskets and you
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-29-2010, 01:11 AM
  5. Just put up my Xmas lights and FAILED
    By glanzergtx in forum Off Topic Discussion
    Last Post: 12-05-2009, 12:30 AM
