Thread: P01260 - last test failed.
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: P01260 - last test failed.
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Can u use a aeroforce scan gauge to case learn
  2. #22 Re: P01260 - last test failed.
    crank learn yes, not sure if "case" is the same thing or not.
  3. #23 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    Ik I used it yesterday to do one where u rec the car to 4to5k rpms until the engine cuts fuel
  4. #24 Re: P01260 - last test failed.
    i know that as a crank learn. so, any better? all that does is sync up the cam and crank sensors. if it was running rough that can make it idle smoother. dont have a thing to do with start up, or the fuel.
  5. #25 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    No still the same issue just going to keep using starter fluid until I can drop it off at a ship but I heard if I say the pcm is tuned they won't work on it
  6. #26 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    Car runs with no issues just won't start will start sometimes right after if I start it asap after turning off
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. zzp pcm failed so im swaping to a gtp pcm
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2012, 01:46 PM
  3. Failed emission test again.
    By jokyfo in forum General Tech Discussion
    Last Post: 12-12-2010, 11:00 AM
  4. failed lim gaskets and you
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-29-2010, 01:11 AM
  5. Just put up my Xmas lights and FAILED
    By glanzergtx in forum Off Topic Discussion
    Last Post: 12-05-2009, 12:30 AM
