Thread: any gains in porting the boost bypass passage?
Results 1 to 18 of 18
  1. #1 Re: any gains in porting the boost bypass passage?
    lapeer michigan
    i dont see it doin anything becuase it works like a wastegate basically, i think?someone correct me if im wrong!!
  2. #2 Re: any gains in porting the boost bypass passage?
    If your ported it larger than the plate in it im sure you would loose boost. I dont think their are any gains to be had by porting it unless you were turbo.
  3. #3 Re: any gains in porting the boost bypass passage?
    Quote Originally Posted by my97gtp View Post
    lets assume the outlet(bottom portion) is ported and not the top/inlet, boost would be generated the same since the BBV plate is shut anyways. i think this would only be changed, if any, at cruise and idle when no boost is initiated.
  4. #4 Re: any gains in porting the boost bypass passage?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    why would you want to bypass more boost?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
