Thread: any gains in porting the boost bypass passage?
Results 1 to 18 of 18
  1. #1 Re: any gains in porting the boost bypass passage?
    Quote Originally Posted by my97gtp View Post
    If your ported it larger than the plate in it im sure you would loose boost. I dont think their are any gains to be had by porting it unless you were turbo.
    lets assume the outlet(bottom portion) is ported and not the top/inlet, boost would be generated the same since the BBV plate is shut anyways. i think this would only be changed, if any, at cruise and idle when no boost is initiated.
  2. #2 Re: any gains in porting the boost bypass passage?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    why would you want to bypass more boost?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
