Thread: Will not start after replcacing fuel rail and injectors
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 136
  1. #1 Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    So I have just installed new injectors and fuel rail on my 01 gtp now nomatter what it will not start before it ran fine everything is hooked up ive checked twice
  2. #2 Re: Will not start after replcacing fuel rail and injectors
    the fpr on the new rail might not be good.
  3. #3 Re: Will not start after replcacing fuel rail and injectors
    Kemmerer, Wyoming
    is everything oem or aftermarket?
  4. #4 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by SgtMarshal View Post
    Everythings oem
  5. #5 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Alright ill check
  6. #6 Re: Will not start after replcacing fuel rail and injectors
    you checked for fuel at the rail yet?
  7. #7 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Yea there's fuel to it how do I check the fpr
  8. #8 Re: Will not start after replcacing fuel rail and injectors
    if you got fuel it should at least try to start. if the vac line off it has gas in it, or smells of gas the fpr is bad.
    what are these new injectors? stock replacements?
    check for spark yet?
    side note, the injector harness can have a bad spot that you aggravated by taking the plugs off. so you can look for a break, or also test the power at the plug, test light works, or you can take a marker light out the head light and push it in the injector plug. you turn the key to run and the bulb should flash a few times, or the test light will flash if its got power. it only flashes a few times then you have to re cycle the key, its the prime for the engine to start. if it dont flash at all you got no power to them.
  9. #9 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    That maybe it because it wants to start but won't I checked the vac line it was dry but it does really smell of gas after a few cranks so I'm guessing bad fpr? They are stock replacements and another question how do I get the fpr off all the vids on YouTube are for the N/A and not supercharged don't know if its different being on the opposite side of the rail
  10. #10 Re: Will not start after replcacing fuel rail and injectors
    GTP Level Member
    Oct 2014
    Do you still have the old FPR off the old rail? Swap?
  11. #11 Re: Will not start after replcacing fuel rail and injectors
    Connect the big plug in front if you left it unhooked.
  12. #12 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by markpa View Post
    Thankfully yes ill probably end up putting it on the new one once I find out how to take it off lol
  13. #13 Re: Will not start after replcacing fuel rail and injectors
    Most are a circlip. Get the clip out.. wiggle..wiggle...wiggle and it's out. Lube the o-ring before you put into the new one
  14. #14 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Alright thankyou
  15. #15 Re: Will not start after replcacing fuel rail and injectors
    I kinda doubt it's an fpr though
  16. #16 Re: Will not start after replcacing fuel rail and injectors
    GTP Level Member
    Oct 2014
    If you step on the gas while starting with a bad FPR sometimes it will start.
  17. #17 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Yea that's what I was trying I think I'm not getting a good seal on one injector I can spin it
  18. #18 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Yea its still not starting the one injector looked like there was a leak but there's no gas smell to it but when I'm trying to start it inside smells like gas
  19. #19 Re: Will not start after replcacing fuel rail and injectors
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    what's the pressure at the rail key on engine off?
  20. #20 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    What or where is that
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
