Thread: Will not start after replcacing fuel rail and injectors
Results 1 to 20 of 136
  1. #1 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    I'd really like to see pics or a vid of the engine is possible. We can see the engine and harnesses etc, maybe we see something and can point out what's wrong.
    The sound of the engine cranking over isn't much help unfortunately. The sound of air whooshing could be where the pistons are etc when you stop cranking. Could be that your airbox is off.
    Have you tried using the carb clean on the floor to fire it up?
    Yes I have unfortunately i havent been able to have anyone crank it while I spray
  2. #2 Re: Will not start after replcacing fuel rail and injectors
    Quote Originally Posted by jetfighterv View Post
    take the intake off, then open the tb and spray right in there for like 5 seconds, then go crank it. if it fires right up and run for like 5 seconds or so your not getting fuel.
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
