Thread: How to Tune the MPG estimate in the DIC.
Results 1 to 13 of 13
  1. #1 Re: How to Tune the MPG estimate in the DIC.
    PA
    Check this link out:
    Linky...
    2001 GSE
  2. #2 Re: How to Tune the MPG estimate in the DIC.
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by Zef_66 View Post
    Linky...
    Zef, you have to be a PT owner to be able to access that site. I could copy and paste, but the secret handshake would be known to everyone, and I, the violator would be pursecuted for my remaiining days.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: How to Tune the MPG estimate in the DIC.
    PA
    Quote Originally Posted by IndeedSS View Post
    Zef, yiou have to be a PT owner to be able to access that site. I could copy and paste, but the secret handshke would be known to everyone, and I, the violator would be pursecuted for my remaiining days.
    I will quote it then. I don't have anything to fear...
    First, if you do tune VE using *idle only* make sure you watch IATs, as they will tend to rise as you just idle, and as they rise, your trims will be all over with a VE tune. You will wind up chasing your tail over and over.
    Second, as far as tuning the DIC for accuracy - I have done exactly what Eddie has, and I have also had great results. My DIC fuel used and mpg are both pretty much spot on now as I check them every time I fill up. You are absolutely right, though. If you don't fill up at the same station, let it click off due to the same pressure, etc, etc, etc, you will get different results. But, in my findings, the error introduced due to these factors is minimal. I had very consistently optimistic fuel used readouts from my DIC vs actual everytime I filled up it was off 7% +/- 0.5%. I think that if you use the same pump and just go "full blast" you can get within a tenth of a gallon or better, which, over 12-13 gallons isn't all that much.
    I'm no expert tuner, but if it were me in your shoes, I would do "the best I can" for the IFR and VE/MAF tables meaning I would calculate IFR using the accepted method (math, percentage) the best that you can figure, and use some maf and available tables to put them in to what you think *should* be right. Then, especially if you are concerned about your DIC accuracy, but also I think it would result in increased IFR accuracy, use the following method:
    1. Drive around. If you are pegging your trims in either direction, you may want to globally increase the maf or something just to bring them into a workable range.
    2. Once you are not pegging your trims, fill up at a station, reset your DIC, and drive your car *easy* for at least a half tank, and then fill up the same way at the same station (if possible, but not necessary). Mark how many % which way your fuel used reads vs actual fuel pumped.
    3. If you can afford the time and gas, you should repeat a couple times to average your % error (which should have reasonable deviation).
    4. If the % error is more than a couple %, or whatever you are comfortable having your DIC accuracy at, then change the IFR table by the % required. ie, If you were reading 10% LESS fuel used, then decrease your IFR, if you were reading 10% MORE fuel used, then increase your IFR, and so on.
    5. Repeat steps 2 and 3 to see if your accuracy has improved. Chances are it has improved linearly (this has been my experience). If it has not improved to your liking, repeat steps 2-5.
    Once you have completed those steps, you can move on to tuning your VE as normal, and then tuning your MAF as normal.
    The reasoning I have behind this method, is that the IFR is the buliding block for everything else, and the VE is the building block for the MAF. So you should tune them in order. I may be the only one (other than maybe Eddie, I think), but I think that tuning the IFR using the DIC is a pretty good way of knowing if your IFR is close for your injectors. This is because I have faith that the calculations used by the computer to derive fuel used rely heavily on the IFR and these calculations, I feel, are probably more accurate than some standard numbers that are used for the stock (non-individually-flow-tested) injectors IFR, and in turn, more accurate than the numbers calculated based off stock for upgraded/different injectors.
    I just reread your original post, and I wanted to clarify my position... I tend to think that the IFR can only be at one spot that is "right." Meaning, that no matter what it is when you start, if you get your DIC accurate, it will end at the same place. And I think that this same place is the "right" IFR for your injectors/car/etc. Basically, I'm saying that you are, in fact, tuning your IFR. This goes for your ve and maf tables too. No matter where they are when you start, if you tune your IFR using the DIC and tune the ve and maf properly, you will end up with the same IFR, ve, and maf tables every time you tune your car, no matter what those tables looked like when you started. The caveat here is that you probably can't affectively tune any of these 3 if your trims are pegged, hence step 1.
    So, just a disclaimer disclaimer... This post is nothing more than a combination of stuff that has worked for me, and some general theory of a novice tuner! I await being disproven, and I probably will be
    2001 GSE
  1. Can You Estimate My 1/4 now?
    By BLACKEDOUTGTP in forum Off Topic Discussion
    Last Post: 01-05-2008, 12:28 PM
