Scottydogs mentioned the small hole in the back of the water pump. What's the best way to visually spot that? I thought there was just a gasket and that's it.
there's a "weep hole" that will dribble coolant when the water pump is going bad. Google the water pumps to see it's exact location. No easy way to see it other than use an inspection mirror. I'm a big fan of uv dye
