Thread: Coolant leak - Need some help
Results 1 to 20 of 21
  1. #1 Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    2005 GTP
    So what I thought was an oil leak at the oil filter, ended up being a coolant leak somewhere, and I am unsure where to start. Possibly the water pump? But I'm not having overheating issues. And it's not a very big leak wherever it is. I've checked the top and bottom radiator hose, and no leaks there. Below is a picture from underneath the car and the picture is upside down, so the oil filter is to the left in this shot.
    Coolant leak - Need some help Attached Images
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: Coolant leak - Need some help
    lower coolant elbow is my guess. follow the outer tube on the alt bracket to the block, feeling for wetness. engine off of course, your treading the belts to reach in there.
  3. #3 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    Thanks. I forgot about those things. From 1-10, how difficult is it to do yourself? 10 being the hardest.
  4. #4 Re: Coolant leak - Need some help
    its a 1 really if you have any experience wrenching on cars.
    just make sure you dont put the longer bolt in the wrong place or you drive it through the valve cover.
    the how to. http://www.grandprixforums.net/threa...coolant-elbows
    make sure you clean all 4 holes where the elbows live really well. light sanding if need be. then oil the o rings well with oil and slide them in.
  5. #5 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    Thanks. I can't see the picture in this thread. I'm looking for the 3rd bolt holding the tensioner assembly.
  6. #6 Re: Coolant leak - Need some help
    http://www.grandprixforums.net/threa...=1512234159072 install this add on then pics show up again.
  7. #7 Re: Coolant leak - Need some help
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    If you still can't see the leak, the easiest way to see it is to clean that side of the engine off, pour in some uv dye form your local auto store, and a uv light and glasses and it'll light up like a Chrismas Tree! (yes, I've been saving that joke all year)
    I had a mystery leak here and it ended up being the crappy hose clamp for the overflow reservoir. Best thing to do though is to clean the area and see where it's coming from.
  8. #8 Re: Coolant leak - Need some help
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by lawadm1 View Post
    There's some decent youtube vids. Try 1AAuto .
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  9. #9 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    I finally found the last bolt, feeling around. I replaced both elbows, so we will see what happens. The funny thing is, it didn't look like they were leaking. Oh well, the car has over 100k miles now, and I don't believe they've ever been done before. If it continues to be a mystery, I'll do the dye test that was suggested. Thanks for all the help. Wasn't too bad of a job...just a little messy.
  10. #10 Re: Coolant leak - Need some help
    if its still there the water pump could be the next step, you can feel wetness under and behind it, it leaks form a small hole back there.
    worst case is its the timing cover.
    could even be a heater hose.
  11. #11 Re: Coolant leak - Need some help
    Aug 2017
    Raytown, MO
    Yup! Welcome to the wonder that is our coolant system. Thank you GM DEX cool!
  12. #12 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    Well, it looks like I'm going to have to go with the dye kit. It's still leaking somewhere, but it's not a huge leak. The belt the alternator is on is squeaking because there's some fluid getting sprayed on there from somewhere. What a pain in the a** this has been. And I think it's leaking the most after running the car, and then it cools down. I'm hoping it's not the worst case scenario previously mentioned (timing cover).
  13. #13 Re: Coolant leak - Need some help
    Aug 2017
    Raytown, MO
    Good luck and let us know! (that is if the forum doesn't shut down by then)
  14. #14 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    Scottydogs mentioned the small hole in the back of the water pump. What's the best way to visually spot that? I thought there was just a gasket and that's it.
  15. #15 Re: Coolant leak - Need some help
    Aug 2017
    Raytown, MO
    there's a "weep hole" that will dribble coolant when the water pump is going bad. Google the water pumps to see it's exact location. No easy way to see it other than use an inspection mirror. I'm a big fan of uv dye
  16. #16 Re: Coolant leak - Need some help
    Nov 2017
    Michigan
    2005 GTP
    Could be the,water pump it is right above the oil filter. Mine was leaking and was dripping on the ground on passenger side of car so it could very much be the water pump. What motor
    Sent from my SM-J700T1 using Tapatalk
  17. #17 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    It's the 2005 GTP engine. And it's definitely somewhere around the oil filter, because that's what I thought was leaking until I got underneath the car and saw the green coolant. I'm going to use the dye as suggested, and probably focus around the water pump. I have 103K on the car, and the water pump is still the original as far as I know.
  18. #18 Re: Coolant leak - Need some help
    Nov 2017
    Michigan
    Yea i got a 02 with 212,000 and,thats what mine was the,water pump
  19. #19 Re: Coolant leak - Need some help
    GTP Level Member
    Oct 2014
    I have had the o-rings on the heater hose connections to the alternator bracket leak also. Lube them up good with Vaseline. Same general area of drip. Mine would only leak after engine shut down.
  20. #20 Re: Coolant leak - Need some help
    Jul 2012
    Bloomington, IL
    I'll check those as well. Thanks. I does seem to only leak after the car has been running, and then is shut off. But it could also be little drips while it's running, and then eventually works it's way down to the ground later on. Hopefully the dye test will tell me, or give me the general vicinity of the leak.
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Coolant Leak
    By Egleone6 in forum General Tech Discussion
    Last Post: 08-16-2012, 08:09 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
