Thread: High Idle stuck
Results 1 to 16 of 16
  1. #1 Re: High Idle stuck
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by eddie07 View Post
    thanks for the idea but its just so weird how this occurred man I went to lunch got food tunred my ac on and got back parked and it idled high had to get towed from work because it didn't go away
    Have you checked the vac line that enters into the car for the HVAC system for a leak, has to be a vac leak somewhere with the +16 LTFT
  2. #2 Re: High Idle stuck
    Aug 2017
    las vegas NV
    yes all my lines are connected i read on another forum that this guy had a simalir issue and he got another pcm tuned and went with stock tune added a few things and drove it at 1.1k rpms and eventually it went away but idk about driving at that high rpm and especially in this las vegas 107+ weather
  1. High Idle
    By rvnwlf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2015, 11:16 AM
  2. High Pressure line stuck
    By HerpDerp1919 in forum General Tech Discussion
    Last Post: 02-28-2015, 10:38 PM
  3. Coolant gauge on the dash is stuck on high?
    By GTP GTP GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2013, 03:41 PM
  4. High Idle/Stuck in 1st after motor swap
    By Dtrick22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2013, 12:06 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
