Thread: High Idle stuck
Results 1 to 16 of 16
  1. #1 High Idle stuck
    Aug 2017
    las vegas NV
    Needing your experience and help with my car.its a 2002 Pontiac gran prix gtp 3.8L SC
    Gtp idles high at idle and gear. 1.8-2.3k Rpm at idle 1.2k Rpm in gear
    Changed
    3x throttle bodie
    3x maf
    3x iacv
    3x tps
    No combination seems to work
    Found a few bad wires and have fixed
    Break clean (flammable spray smooth out idle) vac leak and cannot find one that takes the idle down only if sprayed directly into intake does make the idle go down. Even tried a different pcm Stock tune and still idles high with that pcm I'm at a lost I did the LIM a few days ago and still have that high idle ....
  2. #2 Re: High Idle stuck
    I'd smoke test it to make sure there is no large leak.
    Have you tried starting it with the throttle cable un-hooked. Maybe the cable is holding the blade slightly open?
  3. #3 Re: High Idle stuck
    Aug 2017
    las vegas NV
    both CControl and main cable are off and the TB butterfly valve is shut all the way you can see it thru the honeycomb screen and I'm pretty sure there no leak I used carb cleaner sprayed the obvious spots and no idle change like said I even did LIM and still same problem LTFT +16
  4. #4 Re: High Idle stuck
    Then something must be letting in the extra air.
    Carb cleaner or brake cleaner doesn't always work, why I suggested a smoke test.
  5. #5 Re: High Idle stuck
    St. Louis
    Check the EGR tube. They like to crack and not show with the brake clean trick.
  6. #6 Re: High Idle stuck
    Aug 2017
    las vegas NV
    EGR deleted with code
  7. #7 Re: High Idle stuck
    Aug 2017
    las vegas NV
    thanks for the idea but its just so weird how this occurred man I went to lunch got food tunred my ac on and got back parked and it idled high had to get towed from work because it didn't go away
  8. #8 Re: High Idle stuck
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Quote Originally Posted by eddie07 View Post
    Clogged Cat? Something is causing the Oxy sensors to tell it to add fuel... Right?
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  9. #9 Re: High Idle stuck
    Aug 2017
    las vegas NV
    Full exhaust sd headers and no cat and the tune has the back O2 sensor tuned out
  10. #10 Re: High Idle stuck
    Nov 2011
    NY
    Trim pegged at +16 is a vac leak... Unmetered air is getting in... You have to find it. Deleting the EGR because of a code doesn't fix the leak. And what was the EGR code deleted? Don't you think the two can be related?
    Can't hide from a smoke test, is best way to find leaks. Don't mess around, get a smoker, make one, or take it to someone who has one and give it a shot.
  11. #11 Re: High Idle stuck
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Have you checked the vac line that enters into the car for the HVAC system for a leak, has to be a vac leak somewhere with the +16 LTFT
  12. #12 Re: High Idle stuck
    Aug 2017
    las vegas NV
    its the back o2 that reads +16 ltft ill look up the code foe the egr ina few and I feel like I'm almost positive theres no leak it ran fine I even added a SSIC before it did this thanks coolone
  13. #13 Re: High Idle stuck
    Aug 2017
    las vegas NV
    yes all my lines are connected i read on another forum that this guy had a simalir issue and he got another pcm tuned and went with stock tune added a few things and drove it at 1.1k rpms and eventually it went away but idk about driving at that high rpm and especially in this las vegas 107+ weather
  14. #14 Re: High Idle stuck
    Dec 2011
    Ontario,Canada
    Nope...the rear 02 sensor does not read fuel trims. You did mention above that the rear o2 was tuned out anyhow.
  15. #15 Re: High Idle stuck
    The only sensor you'd need to watch is Bank 1 Sensor 1.
    Anything labeled Bank 2 Sensor 1 or Bank 1/2 sensor 2 do not matter here.
  16. #16 Re: High Idle stuck
    Aug 2017
    las vegas NV
    also forgot to mention I was getting the intermediate tps could and low 5v reference signal but even with new wires from pcm to tps it still threw it and I forgot was the stft and the front o2 would bounce between 100to 900v
  1. High Idle
    By rvnwlf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2015, 11:16 AM
  2. High Pressure line stuck
    By HerpDerp1919 in forum General Tech Discussion
    Last Post: 02-28-2015, 10:38 PM
  3. Coolant gauge on the dash is stuck on high?
    By GTP GTP GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2013, 03:41 PM
  4. High Idle/Stuck in 1st after motor swap
    By Dtrick22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2013, 12:06 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
