Thread: 325 +/- wheel horsepower?
Results 1 to 13 of 13
  1. #1 325 +/- wheel horsepower?
    Hub City
    I'm looking at picking up a BMW 5409 with a tanked engine and I have access to a 2003 GTP that's all smashed up...and my desire to make weird **** work is driving me nuts!
    Basic idea is to adapt the 3.8 to the BMW 420G 6-speed tranny so I can leave the driveline alone. If I can't pull that off then I'll source a T5 and adapt the drieshaft. The rest is tedious boring stuff with making mounts and plumbing systems and wiring.
    What I want to know, though, is what would it take to push the 3.8 up to 325whp? We're talking a 100~120hp boost over stock. Will the stock bottom end be up for that? Can I get it by just cranking up the boost (smaller pulley)? What am I in for here? This is going to be what makes the project a consideration.
  2. #2 Re: 325 +/- wheel horsepower?
    Kemmerer, Wyoming
    you need to increase the exhaust flow out or you will grenade the bottom end. most people run speed daddy headers from ebay. I run an XP cam, and it works well, with some head work, E85, and an intercooler or methanol injection you should be able to hit about 350 hp at the wheels with the smaller pulley of course.
  3. #3 Re: 325 +/- wheel horsepower?
    Hub City
    Considering the project everything past the exhaust ports will have to be custom...I'll be able to make the primaries whatever size needed.
  4. #4 Re: 325 +/- wheel horsepower?
    I would run some stock camaro 3.8 exhaust manifolds, then make it into a custom exhaust.
    You will have to swap camshafts if you want to make anywhere near 300-325whp without trying to jam a stupid amount of boost out of the GEN 3 blower. At the speed it work take to spin the supercharger that fast you'd be creating so much heat that it's very hard to make a lot of power without lots of E85. An intercooler would be a must there as well.
    I'd do a mild cam, a 3.0-3.2ish size pulley with a good tune on 93 pump gas and you should be atleast in the 280-300hp range with lots of torque down low.
  5. #5 Re: 325 +/- wheel horsepower?
    Jan 2015
    United States
    And if the OP takes this advice - you have two different styles of GM RWD 3.8 exhaust manifolds. The most common has a quasi-center dump and then there's a version that was on like 99-01 (approx) that has a rear dump.
  6. #6 Re: 325 +/- wheel horsepower?
    May 2017
    Dirtyzville, Mizzery
    These aren't horsepower motors; they're torque based. No need to rev the crap out of it either, however I'd tell you ten out of ten times to just run the T5 from an FBody, fab up mounts, and find a driveshaft that'll work. Would be easier I'd think than trying to fit a Bimmer tranny to the old V6.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  7. #7 Re: 325 +/- wheel horsepower?
    Jul 2017
    MN
    Quote Originally Posted by makenzie71 View Post
    I have about 310 whp - here is proof. https://www.youtube.com/watch?v=XcFNm7F7GwU&t=3s
    Ingredients.
    1. 3800 series II stock
    2. VS or XP cam
    3. better front manifold as stock is very restrictive.
    4. 60lb injectors
    5. E85 fuel
    6. Deatschwerks E85 rated fuel pump
    7. some tuning on HP tuners.
    Have fun!
  8. #8 Re: 325 +/- wheel horsepower?
    Aug 2017
    NY
    Quote Originally Posted by Toys4life C5 View Post
    Ingredients.
    2. VS or XP cam
    4. 60lb injectors
    5. E85 fuel
    Have fun!
    What else needs to happen to be able to run E85? I may be looking to switch to that on my '07 GT if I can find somewhere around me that has it.
  9. #9 Re: 325 +/- wheel horsepower?
    Jul 2017
    MN
    Quote Originally Posted by madhavok09 View Post
    1. Some tuning with HP tuners. I have a 97 PCM so it may be different than an 07. Easy way is to lie to PCM as to injector size (tell them they are 30%+- smaller than they really) which leads to the 30% more fuel E-85 requires. Timing needs to be increased then quite a bit under high load/WOT areas for the E-85.
    2. Research as many threads as you can find on the subject.
  10. #10 Re: 325 +/- wheel horsepower?
    Aug 2017
    NY
    I've been looking into it. Buy the sad part is I can't seem to find E85 near me at this time. It is something I may still look to do, but I'd just need to find a gas station. Thanks for the input.
    Sent from my SM-G950U using Tapatalk
  11. #11 Re: 325 +/- wheel horsepower?
    May 2008
    Schuyler, NE
    Cam and intercooler will get you there. You could get by on a cam alone if you run better fuel.
  12. #12 Re: 325 +/- wheel horsepower?
    no corn? get a meth kit.
  13. #13 Re: 325 +/- wheel horsepower?
    May 2008
    Schuyler, NE
  1. Max horsepower
    By Dee23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2017, 03:04 PM
  2. Overkill MAF upgrade - 6 wheel horsepower gain
    By Overkill in forum 5.3L V8 (LS4)
    Last Post: 10-28-2014, 01:46 PM
  3. Horsepower?
    By JonnyGrandPrix in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 05:08 PM
  4. Need more horsepower
    By csssaint12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 08:10 PM
  5. K&N Air Intake Horsepower
    By UCF04GPGTPCompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2010, 01:33 PM
