Has anyone added an additional push fan on the front of the radiator to help cool these cars down? or is there a "super amazing" highest flow water pump?
Right now if the temp outside is 80 or above, I don't like running the AC because the temp just keeps climbing. I haven't let it go over 210, and as soon as I shut the AC off it drops back down below 200. But I would love some sort of permanent solution to the threat of overheating.
This is all with a drilled 160, zzp full aluminum oversized radiator, caspers high speed fan switch on full speed.
I don't know if the IC front mount and trans cooler just block the radiator too much or what.
