Thread: Oil pump alignment?
Results 1 to 8 of 8
  1. #1 Oil pump alignment?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Where does the mark on the oil pump sprocket line up to? It really doesn't match up to anything but it is close to the 0 on the rollmaster pump sprocket. Of course any info that I find the pictures don't show up. Any help appreciated
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Oil pump alignment?
    oil pump dont matter, its the crank and cam gear timing marks that matter
  3. #3 Re: Oil pump alignment?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok. I really didn't pay any attention to it. I just happened to notice the dot after I put back on the cover and tightened everything down. I'm glad I don't have to take it apart.
    Thanks man!!
  4. #4 Re: Oil pump alignment?
    if im wrong were both in trouble lol i show over 50 psi all the time. think its ok.
  5. #5 Re: Oil pump alignment?
    Antioch, IL
    There are no marks to time it, it can be installed the wrong way though. If it fits onto the crank and the timing cover bolts down and it still moves then all is good.
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: Oil pump alignment?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Lol Scotty. Fingers crossed!
    it fit in and the cover bolted down fine. Hopefully it's good.
  7. #7 Re: Oil pump alignment?
    hangover park IL
    there is no timing alignment but it is not a bad idea to double-check that the rotating axis centerline's are concentric.
    ~James~ Psychotic Gearhead
  8. #8 Re: Oil pump alignment?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I wonder why they put that mark there for? Maybe a use in another application??
    Turbo, I will try to do what you said but I really don't know what you mean!! LOL
  1. Alignment
    By kissmyss in forum Tires & Wheels
    Last Post: 06-08-2014, 10:19 PM
  2. 2001 grand prix 3800 oil pump install alignment
    By billw19 in forum Introductions/Noob Questions
    Last Post: 09-18-2013, 08:49 PM
  3. Alignment???
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-28-2013, 09:31 PM
  4. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  5. Alignment
    By Iceman6669 in forum Brakes/Suspension/Chassis
    Last Post: 02-13-2012, 05:33 PM
