Thread: Weird idle problem....
Results 1 to 8 of 8
  1. #1 Weird idle problem....
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    So I started my car today (after driving it about 5 times before that) and the RPMs started at about 1000 and they just kept going up and didn't stop until it hit 2000 RPM.
    I though it might be a one time thing so I cut it off and started it again and it did the same thing. I drove it around the neighborhood and the lowest they got was 1100 and that was in drive at a complete stop.
    2001 gtp
    No codes when I scanned.
    Is something broken? Have you guys ever heard of this?
    Sent from my Moto G (4) using Tapatalk
  2. #2 Re: Weird idle problem....
    Sounds like a vacuum leak or the tb blade is sticking.
  3. #3 Re: Weird idle problem....
    Nov 2015
    Olive branch, MS
    That's what I was thinking but I drove it again after letting it sit and it doesn't do it anymore. Might take the throttle body off tomorrow just to be sure though.
    What's the easiest way to check for a vacuum leak?
  4. #4 Re: Weird idle problem....
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
    look with a scan gauge see if you have 18 20 vacuum
  5. #5 Re: Weird idle problem....
    GT Level Member mguzzo's Avatar
    Buffalo NY
    if you have access to a scanner, check IAC counts, if its less than 30 or so you have a vacuum leak
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Weird idle problem....
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by mguzzo View Post
    I'll check on the way home. Is this something I can find on torque pro? That's the scanner I use
  7. #7 Re: Weird idle problem....
    Nov 2015
    Olive branch, MS
    Vacuum stays at 19 or so. Today it was perfectly normal but in the back of my mind I'm still worried there's a problem that I need to find
  8. #8 Re: Weird idle problem....
    May 2017
    Dirtyzville, Mizzery
    To find a vacuum leak; easily...do this.
    Set the scan gauge to read STFT and LTFT (short and long term fuel trims)
    If at any point idling they peg + or - 16.4, you've got a vac leak.
    Plain, and simple.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  1. Weird idle ?
    By Le Patriote in forum Engine
    Last Post: 12-14-2013, 07:51 PM
  2. weird ltft at idle
    By monte0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2013, 07:41 AM
  3. Help with weird KR problem.
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2011, 06:53 PM
  4. Weird Idle
    By mikesarebetter in forum General Tech Discussion
    Last Post: 11-18-2009, 09:47 PM
  5. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
