Thread: Weird Idle
Results 1 to 4 of 4
  1. #1 Weird Idle
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    last night i got home after driving it normally.. no wot runs or even gettin on it really.. pulled into the driveway put it in park and it started wanting to die.. rpms bounced from 500 all the way to 1800 or so than back down and did that several times... got in it this morning and drove about the same distance as the night before and it ran great.. no problems no anything. i don't understand.. it acted like it had a huge vacuum leak.. but those don't just fix themselves.
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #2 Re: Weird Idle
    SE Level Member CityStarz's Avatar
    Nov 2009
    pittsburgh PA
    check engine light? if nothing obvious shows up it could be a bad maf
    L36|Topswap|3.25|NIC cam|JP Double|Comp 105s|SLP Headers|Full stainless 3" to 2.5" Y|Fully Ported Blower|ST2 TB|FWI|PT|LC-1
  3. #3 Re: Weird Idle
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Start it, unplug the MAF and see if the idle levels out. if so, bad MAF. If not, its obvious its something else then.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #4 Re: Weird Idle
    vacuum leaks can come and go with the expansion/contraction of parts.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  3. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
