Thread: 3.4 S/C Pulley
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #1 Re: 3.4 S/C Pulley
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I drove the Imp to work for the last (2) days, which is expressway driving. With regular spirited driving I don't get any kr, when I put my foot in it I get 1-2* before the tranny shifts. The 3.4 really woke the Imp up, I have an appt. to have the lim done at the stealer. The car will be parkled until that day comes, then I'll do a seafoam clean up and finish installing the other items.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: 3.4 S/C Pulley
    Donating Users blowfishRus6's Avatar
    g.a.
    good luck. i cant wait to get more boost
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: 3.4 S/C Pulley
    the step from a stock pulley to a 3.5 or 3.4 is crazy. then just think of what a 3.2 or 3.0 would do.
  4. #4 Re: 3.4 S/C Pulley
    g.a.
    ahhh must be nice!! i might have to go methy myself
    its slow.
  5. #5 Re: 3.4 S/C Pulley
    im sure youll hear about how my setup comes together. im almost done putting it all on..but i have another problem a-brewin'....low oil pressure...
  6. #6 Re: 3.4 S/C Pulley
    g.a.
    oohhh nose!!
    deff looking forward to it. im really startin to like that set-up myself.
    its slow.
  7. #7 Re: 3.4 S/C Pulley
    Jan 2009
    ny
    The Imp goes in for the Lim repair tomorrow, gotta love a factory warranty. I hope to get her back by the weekend, so I can install the plog & crossover. I swapped the overkill pcm with the factory, so I don't get a surprise flash update and ruin my overkill. I always do my own work, this is the first time in 20yrs that I let someone else work on my car. I'm going to miss her it's going to be a sad day for me.
  8. #8 Re: 3.4 S/C Pulley
    GTP Level Member David99GTP's Avatar
    Florida
    Good info guys. I just bought a 3.4 for my 99 GTP and wondered if it will make much of a difference. I have a DHP PCM from PFYC. I'm gonna get a tune after it is installed but will have to drive it a bit first.
    I have a wizaired CAI, Borla Exhaust, U bend delete, and Will be installing SLP headers next month. I can't wait!
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  9. #9 Re: 3.4 S/C Pulley
    TDCRacing
    Guest
    3.4 will make a huge difference from stock.
  10. #10 Re: 3.4 S/C Pulley
    Apr 2008
    Chillin at the Beach , VA
    Don't forget your colder plugs and 180 t-stat if it hasn't been done already.
  11. #11 Re: 3.4 S/C Pulley
    Florida
    Yeah I bought colder plugs and a T-Stat. I already have fuel rails and 42.5lb injectors so fuel delivery is no issue. This summer is a stage 3 IC, port the S/C and then may need a Tranny LMAO.
    I got tired of all show and no go. Time to make this thing scoot!
    1999 GTP
  12. #12 Re: 3.4 S/C Pulley
    Apr 2008
    Sounds like your going to be good. Yeah, same here. I was at car shows every weekend. Ready to dig into the motor know and finish up the little body mods I have started.
  13. #13 Re: 3.4 S/C Pulley
    Jan 2009
    ny
    I got the Imp fixed, I'm back in business. I spoke to the mechanic and he said it wasn't bad he seen worst. The oil was just seeping on the outside, no internal breach of the gasket. The Lim, valve covers, coolant and oil was replaced. Here are the part #'s from the receipt for those interested. 89017825 gasket kit, 24503937 valve cover gasket, 12346290 coolant, 12378521 sealant, premium oil, 12490147 filter.
  14. #14 Re: 3.4 S/C Pulley
    Apr 2008
    Glad to see your baby is home and fixed. Bet you were glad to pick her up.
  15. #15 Re: 3.4 S/C Pulley
    Jan 2009
    ny
    I sure was, now I can finish modding and enjoy.
  16. #16 Re: 3.4 S/C Pulley
    Apr 2008
    Sweet!!!!
  17. #17 Re: 3.4 S/C Pulley
    Jan 2009
    ny
    I changed the plugs to AL 104's, the install wasn't bad I had minor difficulties with removing the heat shields though. I didn't reuse them or tilt the engine forward, having the right tools = priceless. The next change will be cake without the h/s, I reused the stock wires for now. I also changed the S/C oil and replaced the cruise control buttons the lettering was coming off.
    Btw, the plugs that were removed were AC Delco Iridium #12568387 and the gap was a little more than .60
  18. #18 Re: 3.4 S/C Pulley
    Elmira
    right now my car is stock can you drop the pulley size with no bad ramifications and without further modification?
  19. #19 Re: 3.4 S/C Pulley
    Barksdale AFB, LA
    Quote Originally Posted by DerekG12 View Post
    No. Otherwise GM would've done it to start with.
    2009 Subaru Impreza WRX STI
  20. #20 Re: 3.4 S/C Pulley
    Go search for some threads. There are MANY about why you can't drop a pulley size.
  1. GTP pulley set up
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 08:36 AM
