Ok so I just got over my last issue of the car not starting due to a malfunctioning CPS. I was then having trouble with putting the crank pulley on the right way. I put it on not keyed the right way three times in a row. On the second to last time I test drove it, the idle was high, and the idle would surge real bad. Also when i floored it, the motor got up to 70 on the knock sensor. I took the crank pulkley off again to confirm that it was on wrong for the third time, as I etched a new notch right between my last notch i etched and the real one from GM. I do not understand why the crank does not have the bump go all the way down the crank shaft. its like a guessing game every time. This last time I put it on it felt real good. The idle is now a little lower and it wasn't surging at idle. Then i took it out and at the peak of rpm i was getting anywhere from 7-33 on the knock sensor, but non when driving normal or giving it some gas. Then when i parked in the driveway it was surging a little. I could also hear the fuel pump whining with the rhythm of the surge. Mind you when i first put my motor together it had no knock and ran like a champ. However I am not sure if I had the back knock sensor connected or not when i ran those tests originally after the put together. I think i only had the front one connected. Do you guys think that I still have the crank off a little bit or does it sound like the fuel pump is failing on me now too? If you guys think it is the crank being off does anyone have any tips on how to get it on right? I pushed it down and its always hard to spin it so i never know when the pulley is keyed in right. Below is the link to the thread that explains how all the problems started with my ignition problem, if it might provide clues for you. Thanks a lot in advance for any input. BTW i am still running the stock pulley, but have all of the other mods in my sig.
http://www.grandprixforums.net/f18/i...use-14267.html
