Thread: P0140 code help
Results 1 to 5 of 5
  1. #1 Re: P0140 code help
    Jun 2017
    Alberta
    Ive never tried making one. But zzp has one, I cant remember if they have a picture or not. Ill ask my bro, but you need something to send fluctuating signals back. The no comunication is a lack of signal change.
    Sent from my SM-G920W8 using Tapatalk
  2. #2 Re: P0140 code help
    Nov 2015
    WI
    So after further research and learning the differences in how manufactures monitor cat efficiency the electrical circuit i made will not work for 2000 GM vehicles.
    The computer is looking for a fluctuating passing examples 4.5 to -4.5 volts passing zero. The circuit i made dropped the voltage but did not allow it to pass zero. This worked on my Contour SVT because it only looks for a voltage delta front to back.
    I was able to get the code to stay off by removing the circuit and installing 2 spark plug non foulers moving the sensor out of the main exhaust stream.
  1. P0140- Bad Cat or Sensor?
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 02-08-2016, 10:58 PM
  2. P0140
    By alivepills in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2010, 05:07 PM
  3. P0140 code and boost gauge acting weird
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-14-2009, 07:50 AM
  4. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2009, 08:12 PM
  5. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:34 AM
