I should know better than to listen to what the instructions says lol . ok Scotty thanks . I have Trans apart and waiting for channel plate so while I waiting I will put new pan gasket on and clean up bottom of motor . it will be nice to have no leaks under . of course that's assuming I can get the trans back together and it still works LOL . I put both Valve cover gaskets in last year cause they were leaking . so I hoping this will stop all leaks it does look like the bolts are more of the problem then the pan gasket itself . I will make sure I use thread sealer
