Thread: removing rough casting from LIM l32
Results 1 to 9 of 9
  1. #1 removing rough casting from LIM l32
    SE Level Member Macksauce's Avatar
    Mar 2014
    Maryland
    Scored a new gen5 to put on my car and I also grab it's Lim while at the junkyard. For some reason I decided that this go around, after Im done sanding polishing the blower case that I wanted to do the same to the Lim. And I'm about half way done doing that job now and it hit me like whoa! Should I even be doing this to the lim ? Would this mess anything up? So I search the web and I found info about air turbulence which I understand now . But when I get on here I find nothing about polishing the Lim out!!! So could u fine knowledgeable folks enlighten me!? Can removing the rough casting out of the Lim be done or am I about to cause myself a new problem?
  2. #2 Re: removing rough casting from LIM l32
    HUDSON
    Removing the rough casting finish wont hurt anything but maybe your hands and arms from all the labor needed, not to mention cost of materials and tools.
    Just dont change the size or shape of any of the ports.
  3. #3 Re: removing rough casting from LIM l32
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Agreed. It won't hurt anything, but don't do more than smooth it out and polish. The runners are so short though, you probably won't see any gains unless you ported, polished, and volume matched the chambers, and then probably not much. I'd say it'd be less than 5whp at 6000 rpm if anything.
  4. #4 Re: removing rough casting from LIM l32
    Kemmerer, Wyoming
    you can port the runners, but it's going to cause more turbulence if your heads aren't ported. one thing you could do is make a knife edge out of the bottom bar that runs down the middle. it is a lot of work to smooth everything out.
  5. #5 Re: removing rough casting from LIM l32
    May 2008
    Schuyler, NE
    Don't polish. Just smooth it. There really aren't much for gains though. You'll maybe gain a couple hp with all this work.
  6. #6 Re: removing rough casting from LIM l32
    Mar 2014
    Maryland
    Thanks guys I'm definitely going to do all y'all said and it's cool I kinda figured it wasn't going to gain if any hp but ill enjoy the view of it until it's time to bolt it on lololol
  7. #7 Re: removing rough casting from LIM l32
    Mar 2014
    Maryland
    Quote Originally Posted by SgtMarshal View Post
    Thats a great idea about making a knifes edge of the split! Do you think there's alot of metal over the coolant path underneath the split? I'd hate to work my way into that area.
  8. #8 Re: removing rough casting from LIM l32
    Kemmerer, Wyoming
    I'm not sure about that
  9. #9 Re: removing rough casting from LIM l32
    May 2017
    Dirtyzville, Mizzery
    Billboost did a How To on hogging out the LIM correctly.
    Check around for it...I know it's out here somewhere.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  1. Cylinder Head Casting Numbers ?
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2017, 11:10 PM
  2. Best head casting #?
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2013, 11:37 AM
  3. I need l32 cylinder head casting numbers if anyone has a valve cover off
    By theonlysi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 11:37 PM
  4. L67 vs L32 Heads, casting #, how to tell the difference?
    By RegalGS98s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2011, 08:10 AM
