Thread: Installing non venturi pump in a venturi canister?
Results 1 to 8 of 8
  1. #1 Installing non venturi pump in a venturi canister?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I have a 99 gt so i assumed my pump was non venturi so I got an aem e85 non venturi pump. I pulled the pump tonight and it was a Delphi replacement with venturi. So I've seen threads where people have installed a non v pump in a v canister but most people say drill a hole or multiple in the canister. The question is where do I drill and what size holes? This is strictly a temporary thing as soon as I'm able I'll be getting a non venturi canister but since I already have things taken apart id like to get it installed. Thanks for the help everyone.
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Installing non venturi pump in a venturi canister?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I drilled holes about a 1/4 inch around the bottom part of the canister walls. I used a 3/8ths drill bit. When I get to a 1/8 of a tank or so it will stumble a bit during a hard stop
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: Installing non venturi pump in a venturi canister?
    Oct 2015
    Quote Originally Posted by BoostedPontiac View Post
    Perfect thanks a lot man!
  4. #4 Re: Installing non venturi pump in a venturi canister?
    Apr 2014
    South Haven, MI
    1/4 inch from the bottom all around lol
  5. #5 Re: Installing non venturi pump in a venturi canister?
    Oct 2015
    3/8 seems kind of big lol
  6. #6 Re: Installing non venturi pump in a venturi canister?
    Oct 2015
    Well I got it installed with the holes drilled like boosted Pontiac said and so far it seems to be running great although I do have half a tank so I'll have to see how low I can go before it starts giving me problems. Thanks man!
  7. #7 Re: Installing non venturi pump in a venturi canister?
    Apr 2014
    South Haven, MI
    Like I said earlier, my gtp will stumble due to fuel sloshing forward and away from the pump during harder stops. My solution is to keep the tank at least half full stall times. My turbo regal was different though. Same pump and canister drilled out but I could to below an 1/8 to the low fuel light with no issues
  8. #8 Re: Installing non venturi pump in a venturi canister?
    Oct 2015
    Ya I think I'm just going to go fill up a couple gallon gas tank and drive it till it starts displaying negative symptoms so I know where my limit is at. Hopefully I'll have a regular non venturi pump in a week or two though. 😀
  1. Fuel Pump Canister Info-97-00 Venturi Style
    By 40thAnnGTP2002 in forum General Tech Discussion
    Last Post: 08-14-2016, 06:47 PM
  2. ISO Venturi style fuel pump canister.
    By JDrach in forum Wanted To Buy - Parts
    Last Post: 08-20-2014, 06:13 PM
  3. I put a non venturi pump in a venturi canister.
    By Frosty in forum General Tech Discussion
    Last Post: 08-14-2013, 12:52 AM
  4. venturi fuel pump canister
    By Maximum Gnarnage in forum Wanted To Buy - Parts
    Last Post: 03-23-2013, 06:22 PM
