Thread: I put a non venturi pump in a venturi canister.
Results 1 to 3 of 3
  1. #1 I put a non venturi pump in a venturi canister.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    So my stock pump decided that it just wasn't feeling like keeping up anymore. Car is a 01 gt officially so I figured ok this will be easy buy a non venturi pump and life is good. Picked up a AEM E85 320lph pump off of zzp and once it came in started the install. All was well untill I started taking the canister apart and discovered a venturi canister..... Turns out back when I was 15 and first got the car I had to change canisters (Old one snapped off in the tank for whatever reason) and I put a venturi canister and pump in. Well ****........
    Looked at it and decided to give it a try. Cut that weird rubber grommet thing at the bottom of the stock pump to fit my aem pump and it all fit ok. Didnt touch the canister AT ALL. Had to use rubber line because the new flexible corrugated line was impossible to get on. Crimped and heat shrinked and then heat shrinked again all the wires. Installed the new level sensor and put it all back in.
    Been driving the car a week now and had it down well into the empty range and all the way up to full and haven't had any issues yet. Am I some magic mechanic or is it really that easy to put a non venturi pump in?
    Photo album of what I did
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  2. #2 Re: I put a non venturi pump in a venturi canister.
    Max Cook
    Guest
    Lol that rubber hose stuff sucks but it is REALLY hard to get the stock tube on that pump. We fought with it for quite awhile on my car. Did manage to get the stock tubing on though. I am running the same setup really. Venturi style cannister with AEM non venturi style pump. I am told it is fine as long as you dont let it get much under 1/4 of a tank as then it can have trouble keeping the cannister full. Was also told to drill a hole in the side of it but there was a hole already in the bottom so we left it.
  3. #3 Re: I put a non venturi pump in a venturi canister.
    Apr 2011
    South Dakota
    The way I plumbed mine it does not draw from the canister at all it uses the stock sock.... As far as I can tell the canister could be empty as long as the sock has fuel in it..... Ran it down FAR into the empty range with several LONG wot pulls and had no fuel issues untill I damn near ran out of gas looking for a e85 station. Fuel needle was a 16th of an inch below the last mark on the fuel gauge so thats when it always used to sputter and die anyways.
    I love Decker<3
  1. venturi fuel pump canister
    By Maximum Gnarnage in forum Wanted To Buy - Parts
    Last Post: 03-23-2013, 06:22 PM
  2. Venturi Pump
    By djrepoman in forum General Tech Discussion
    Last Post: 03-06-2013, 10:13 PM
