Thread: Methanol injection
Results 1 to 11 of 11
  1. #1 Methanol injection
    Oct 2012
    Ipperwash Ontario
    Hi everyone where should you put the injection nozzle on a supercharged l67
  2. #2 Re: Methanol injection
    Apr 2016
    I'm tapping the lim for water meth an then tapping the tb spacer for nitrous
    Sent from my LG-H901 using Tapatalk
  3. #3 Re: Methanol injection
    May 2008
    Schuyler, NE
    For normal amounts, it's best to put it in a tb spacer or drill and tap the blower housing for the nozzle.
  4. #4 Re: Methanol injection
    Apr 2016
    Atfer the maf is best I've learned
  5. #5 Re: Methanol injection
    Oct 2012
    Ipperwash Ontario
    Ok thank you so I could put it in the sc case I think thats where it will mix with the incoming air.I have seen picts with them in the lower intake but I dont think you will get a even mix just my thoughts
  6. #6 Re: Methanol injection
    May 2008
    Schuyler, NE
    There is a thread on clubgp discussing location in the lim to put the nozzles. But for most, you are better off before the rotors. It'll raise the efficiency of the blower by doing so.
  7. #7 Re: Methanol injection
    Oct 2012
    Ipperwash Ontario
    Thank you you see so many different opinions on this
  8. #8 Re: Methanol injection
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i have a nozzle 10 in evap port of gen v and 2 nozzle 3s in the lower intake just under the intercooler running a 2.55 pulley 23.5 deg timing
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  9. #9 Re: Methanol injection
    Oct 2012
    Ipperwash Ontario
    On more question will I need a tune after I instll my meth injection?
  10. #10 Re: Methanol injection
    May 2008
    Schuyler, NE
    It's hard to say. You would need a wideband to be able to tell.
  11. #11 Re: Methanol injection
    Donating Users
    Kansas City
    You could spray the meth to kill the KR; HOWEVER, you could also flood it out and overkill it. Get it tuned via a wideband and an in-car tune. Don't bother with the dyno crap. Then you'll know how it behaves on the street...toss on a smaller pulley...crank the timing, go from there.
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  1. methanol injection !
    By 2000supercharged in forum General Tech Discussion
    Last Post: 01-29-2013, 05:31 PM
  2. Methanol Injection On near stock gtp?
    By dert in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2011, 12:20 AM
  3. Methanol Injection ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-01-2010, 08:28 PM
  4. methanol injection questions
    By blessed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 11:15 AM
