Thread: OBD2 Scanner aps
Results 1 to 9 of 9
  1. #1 OBD2 Scanner aps
    Oct 2012
    Ipperwash Ontario
    Just wondering how accurate these aps are? I am using the obdlink MX Wi-Fi in my obd2 port. The aps I am using are Dashcomand and Obdlink and they seem to be very responsive. According to them I am getting 310 hp and 315 ft-lb of torque. Now if this is accurate would that be to the wheel? All options are welcome I have never had my car dynoed so I am not sure what the real numbers are.
  2. #2 Re: OBD2 Scanner aps
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Polling speed the adapter matters more than the app. Wired had the fastest PIDs.
    I have no idea about the numbers, but those seem synthetic. My guess would be like %18, +/-%2 drivetrain loss on a FWD.
  3. #3 Re: OBD2 Scanner aps
    just ask yourself, how does a app tell me i make more hp/tq then the factory crank rated hp/tq numbers?
  4. #4 Re: OBD2 Scanner aps
    Oct 2012
    Ipperwash Ontario
    Lol sorry my mods are 3.4 zzp mps,cai, zzp power log zzp 3" downpipe with high flow cat, no res, 2.5 exhaust with custom stainless steel mufflers, 8mill wires, ported supercharger, overkill pcm, autolite 104 plugs I think that is it
  5. #5 Re: OBD2 Scanner aps
    you still dont have those numbers. cammed with intercoolers or e85 and heads fight to hit 325.
  6. #6 Re: OBD2 Scanner aps
    Oct 2012
    Ipperwash Ontario
    Ok thank you was just wondering as my speed rpm fuel use and engine temp all match what the car says. Just going to get it dynoed after I instll my meth injection so I have some real numbers
  7. #7 Re: OBD2 Scanner aps
    thats the only true way to know what hp you got. and even then brand to brand, dyno's vary.
  8. #8 Re: OBD2 Scanner aps
    Oct 2012
    Ipperwash Ontario
    Ok thanks would I have to get another tune when I install my meth injection if so I would do both at the same time
  9. #9 Re: OBD2 Scanner aps
    pretty sure you need to lean out the fueling when spraying or you end up to rich.
  1. Obd2 and laptop?
    By Goldenrocket06 in forum Introductions/Noob Questions
    Last Post: 12-07-2015, 11:47 AM
  2. Inexpensive OBD2 scanner WITH ABS and SRS
    By bradycatsmokey in forum General Tech Discussion
    Last Post: 12-14-2014, 02:27 PM
  3. OBD2 Scanner wont connect to ECU. . .
    By KIRKADAMS in forum General Tech Discussion
    Last Post: 07-09-2014, 04:03 PM
  4. OBD2
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-19-2011, 02:08 PM
  5. Bluetooth OBD2 Scanner
    By Jackd90 in forum Audio, Security & Visual Electronics
    Last Post: 02-26-2011, 10:08 AM
