Thread: Boost problems
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Boost problems
    Mar 2015
    Western North Carolina
    heres another link to the video https://www.youtube.com/watch?v=3j59aGmyusY&t=2s thanks guys
  2. #22 Re: Boost problems
    Jeebus, what's with the 90ยบ bend for that intake.
    Audio makes it sound like it has a bad exhaust leak too.
    If only you had a tuner this could be spotted pretty easy if it was a sensor problem. I too used to watching data logs to find peoples problems instead of asking questions lol.
  3. #23 Re: Boost problems
    Mar 2015
    Its got a stuck lifter its not 90 bend its a flex hose run into the fenderwell i can fix the intake hose if it might be a problem yea i wish i had a tuner it would be alot easier i checked all the exhaust an didnt see any leaks i dont feel it blowing out anywhere but ill go back over it an double check it again
  4. #24 Re: Boost problems
    i see a garleak gasket. they got a real bad rep for leaking.
  5. #25 Re: Boost problems
    Oct 2014
    portland oregon
    Lol our cars are so close to the same look. I second the exhaust leak.. might be cheaper to buy a tuner then to start yarding out parts that may not be a issue.. I dont have one either but its on my short list for sure
  6. #26 Re: Boost problems
    Mar 2015
    Yea its the green zzp sc gasket i never had a problem with one b4 but idk ill take any suggestion
  7. #27 Re: Boost problems
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    You say it has a stuck lifter... Is it fixed? Also is that intake a restriction? That's a sharp bend and long small hose. If you can hear that intake sucking air at idle imagine at WOT. I would pull the hose and try a couple runs with a filter right off the MAF. I would think the intake is restricting flow.
    Your BBV looks right and is moving.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. Boost problems
    By BLACKanREDgtp in forum General Tech Discussion
    Last Post: 02-20-2017, 11:16 PM
  2. Boost problems
    By BLACKanREDgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2015, 09:28 AM
  3. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
  4. 99 Gtp boost problems
    By justrunningagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 05:40 PM
  5. 2005 GTP Comp G Boost problems!
    By 05GTPcmpg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 11:00 PM
