How many KPA's does the MAP read at full throttle?
Should be upwards of 170-180kpa if you are setup to make around 9-10psi.
Move your vacuum line source to see if you boost gauge changes.
Perhaps the BBV is causing this to, unplug it and see if you get more boost.
