Thread: Ticking under boost???
Results 1 to 6 of 6
  1. #1 Ticking under boost???
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Whats up folks...
    Damn GTP just started this ticking under boost. Roll slightly into the throttle and get a fast tick. I was thinking maybe header leak. No biggie. Then this morning, I cant get over 10 PSI (Ive seen 13). Im a little lost. I was thinking LIM but I dont have a miss. Im not losing coolant. If anything, she leaks oil like a SOB. LOL.
    The ticket SOUNDS like a pulsating boost leak. No misfire or anything. Just the tick (more like a flutter). I will get some carb cleaner and start hunting.
    Any other suggestions?
    Thanks!
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  2. #2 Re: Ticking under boost???
    on a cold start it will leak its most if its the headers, they put your hands around the headers to feel for a leak. carful, they got hot pretty fast.
    the boost, its colder out is my guess. i used to make 10 in summer on my 3.4 and 12 in the winter.
  3. #3 Re: Ticking under boost???
    Apr 2013
    Waldorf MD
    This is some random crap. Now it's not doing it. I'm driving. Up to operating Temps. No noise. SMH
  4. #4 Re: Ticking under boost???
    Apr 2013
    Waldorf MD
    OK. So whatever this is, its getting louder. SMH. Its not the headers. I checked that. I need to start hunting for vacuum/boost leaks. I can only get 9 psi now. The weather in the DC area has been on a cracked-out see-saw. From highs in the 20s to highs in the 70s. And back. Boost level is the same...
  5. #5 Re: Ticking under boost???
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Can you hear if the fluttering is coming from under the hood, under the car, general area? My thoughts of candidates:
    Leaky flex on the downpipe
    Vacuum T under the SC snout tends to rot and break
    so does the 180 degree vacuum coupler at the throttle body
    still have EGR? cracked EGR flex tube?
    you could use some seafoam and make smoky smoky to find an exhaust leak.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Ticking under boost???
    Apr 2013
    Waldorf MD
    Leaky flex on the downpipe I hope not! LOL!
    Vacuum T under the SC snout tends to rot and break I will check that..
    so does the 180 degree vacuum coupler at the throttle body I will check that..
    still have EGR? cracked EGR flex tube? Yes, it still has it. I bought the delete kit but I havent installed it yet. Maybe its time?
    you could use some seafoam and make smoky smoky to find an exhaust leak. And the neighbors will KILL me. LOL!
  1. boost gauges not working? and no boost at full throttle
    By jeannelle101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2016, 11:23 AM
  2. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  3. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  4. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
