So far i have the lower intake gasket changed, did the LIM modifications, valve covers and gaskets replaced, AL coolant elbows, Speed Daddy headers installed, bought a MPS and found out the car already had a dropped pulley of 3.4 so i will have a 3.4 press on pulley and 3.8 MPS pulley for sale soon along with the puller.
Questions i have comes to the headers. The starter positive wire seem way to close to the headers, does that need to be protected? The rear header is touching the trans dip stick and there is a brake line which i think has been replaced (not sure its the stock routing) touching as well.
Has anyone had issues with heat from headers causing issues or possible fires?
