Thread: 06 grand prix misses when I accelerate hard.
Results 1 to 15 of 15
  1. #1 06 grand prix misses when I accelerate hard.
    Dec 2016
    Iowa-IA
    When I accelerate hard my car misses, the CEL light flashes. I put new coils, plugs and wires on it.
  2. #2 Re: 06 grand prix misses when I accelerate hard.
    St. Louis
    What type of plugs (copper, iridium, platinum?). What brand of coils? Stock coils are known to be the best so if you "upgraded" to another brand could be your issue as well.
  3. #3 Re: 06 grand prix misses when I accelerate hard.
    could also be a clogged cat, stop flooring it. the flashing cel is telling you a catastrophic condition exists. aka stop going WOT till you figure it out.
  4. #4 Re: 06 grand prix misses when I accelerate hard.
    May 2008
    Schuyler, NE
    What cylinder(s) is it missing on?
  5. #5 Re: 06 grand prix misses when I accelerate hard.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Was this happening before or after the new parts?
    GPONA #1 Cyber Bully
  6. #6 Re: 06 grand prix misses when I accelerate hard.
    Enfield, CT
    My guess is 2 of the new plugs are cracked. If the CEL flashes like crazy, I'm betting raw fuel is being dumped into the exhaust due to plugs not firing.
    Sent from my VS985 4G using Tapatalk
  7. #7 Re: 06 grand prix misses when I accelerate hard.
    Dec 2016
    Iowa-IA
    Stock ac delco plugs, duralast coils. It starts missing at 3000 rpms but if I get on it hard and then let out of it, it acts fine. I was thinking it was the fuel filter but the 06 have a non serviceable fuel system....only filter is in the tank....dumb in my opinion.
  8. #8 Re: 06 grand prix misses when I accelerate hard.
    Dec 2016
    Iowa-IA
    #6 cylinder is the one that registers but I thinking it's more than one cylinder
  9. #9 Re: 06 grand prix misses when I accelerate hard.
    Topeka, KS
    Replace cylinder 6 plug
    Sent from my VS990 using Tapatalk
  10. #10 Re: 06 grand prix misses when I accelerate hard.
    Quote Originally Posted by rynoman03 View Post
    It's got new plugs and wires goob.
    Check the coil and injector. Swap them out with another cylinder and see if it follows the misfire.
    That's free.
  11. #11 Re: 06 grand prix misses when I accelerate hard.
    GTP Level Member
    Oct 2014
    Could have cracked a plug that happens
  12. #12 Re: 06 grand prix misses when I accelerate hard.
    Jan 2017
    Greenwood, IN
    I'm having the same issue. I currently code for random cylinder misfire and a code for the supercharger charging circuit that comes up if I accelerate too hard. Car also chokes and rattles at that point. If I ease into the acceleration it's fine. The CEL flashes. Similar symptoms. Following.
  13. #13 Re: 06 grand prix misses when I accelerate hard.
    GTP Level Member
    Oct 2014
    Sounds like a bad coil
  14. #14 Re: 06 grand prix misses when I accelerate hard.
    Dec 2016
    Iowa-IA
    Okay more symptoms to add, temp gu age is normally below half. Yesterday it went just under 3/4 mark...not to the red. The. I would have heat from the heater sometimes, other times it would be cool air......are the series 3 known to have intake gasket issues or am I looking at one or both head gaskets bad?
  15. #15 Re: 06 grand prix misses when I accelerate hard.
    flush the heater core, change the t stat, top off and bleed the coolant,. fill your overflow tank to the line on it. open the rad cap and check the level the next few mornings when its ice cold. watch for any leaks. top off if need be. first morning it might be a inch or so low.
    if you never flushed the coolant, nows as good a time as ever.
  1. 2000 Grand Prix GTP hard start
    By killertoma11 in forum General Grand Prix Discussion
    Last Post: 05-14-2015, 04:58 AM
  2. 2002 Grand Prix stalls, misses, erratic tach
    By Dobbs in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-16-2013, 11:23 AM
  3. Hard Starting 92 Grand Prix 3.1
    By verlando in forum General Grand Prix Discussion
    Last Post: 11-03-2012, 10:25 PM
  4. 2001 grand prix hard to start
    By 01grandprix3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2012, 10:36 AM
  5. hard wiring HUD in a 98 grand prix gt
    By bowtieguy87 in forum Audio, Security & Visual Electronics
    Last Post: 10-29-2009, 06:33 PM
