Thread: External coolant leak
Results 1 to 20 of 33
  1. #1 External coolant leak
    Dec 2016
    houston
    Hello everyone i have a problem. i have a 2007 Grand Prix Gt i have a external coolant leak and its preety bad . ive changed the water pump, coolant elbows, radiator and thermostat.i still get a puddle of coolant on the ground
  2. #2 Re: External coolant leak
    GTP Level Member
    Oct 2014
    Check the o rings on the heater hose connections.
  3. #3 Re: External coolant leak
    your gonna have to tell us where the puddle is under the car. or some pics would be great too.
  4. #4 Re: External coolant leak
    Dec 2016
    houston
    yeah i got picfs trying to upload them. i rubbed my hand under the hoses at the firewall dont seem to be wet.
    [IMG]file:///C:/Users/Delbert%20Wc/Desktop/Car%20puddle/20161209_150701.jpg[/IMG]
  5. #5 Re: External coolant leak
    Dec 2016
    houston
    the puddle is running down the drivers side of the car forming 2 streaks between the driver side tire it also get small going to the passenger side. making you think its coming from the pulley side of the engine. but everrything has been replaced annd the same problem
  6. #6 Re: External coolant leak
    up load to fb or photo bucket, what have you, then right click the pic copy its url addy and past it in the pic icon window.
  7. #7 Re: External coolant leak
    Dec 2016
    houston
  8. #8 Re: External coolant leak
    you cant up load from your pc to the site, it wont work. pics need to be hosted on line some place. then linked here.
  9. #9 Re: External coolant leak
    you can rent a pressure tester at the parts store, free rental really. it goes on as the rad cap, you then pump it up to 16 psi and look for the leak/
  10. #10 Re: External coolant leak
    Dec 2016
    houston
    yeah according to the radiator shop theyput a preesure test on it but could find the leak because it wouldnt leak bad. they should have put it on the rack to look under the car
  11. #11 Re: External coolant leak
    Dec 2016
    houston
    here is a pic
    External coolant leak Attached Images
  12. #12 Re: External coolant leak
    you made it to small to get it to up load to the site, no idea what im looking at there. host it else where on the net.
    http://www.grandprixforums.net/threa...es-for-dummies
  13. #13 Re: External coolant leak
    Dec 2016
    houston
    here is a pic of the leak at another time
  14. #14 Re: External coolant leak
    Quincy, Mass
    Check under the throttle body, there's a coolant passage in the throttle body.
    No more GP 04 Impala SS Indy:
  15. #15 Re: External coolant leak
    Dec 2016
    houston
    hmmmmmm ill look ive had the throttlebody off about a month ago and i saw no coolanf then
  16. #16 Re: External coolant leak
    GTP Level Member
    Oct 2014
    O rings are in the alternator bracket.
  17. #17 Re: External coolant leak
    Dec 2016
    houston
    are you talking about the coolant elbow o rings?
  18. #18 Re: External coolant leak
    GTP Level Member
    Oct 2014
    No. The heater hose connections to the alternator bracket are a loose fitting connection with o rings.
  19. #19 Re: External coolant leak
    Dec 2016
    houston
    ok ill check no those two connections is dry as a powder house
  20. #20 Re: External coolant leak
    GTP Level Member
    Oct 2014
    Mine was just leaking out of the blue. So that's why I mentioned. Pics or video would help
  1. External coolant leak around tb/uim area?
    By tom5170 in forum General Tech Discussion
    Last Post: 12-13-2016, 11:52 PM
  2. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  3. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Coolant leak
    By john breit in forum General Tech Discussion
    Last Post: 02-12-2011, 05:12 PM
