Thread: Problem After Dealer Recall Performed
Results 1 to 7 of 7
  1. #1 Problem After Dealer Recall Performed
    Apr 2014
    Utah
    Just had the dealer do the front valve cover recall to my recently acquired 04 comp g. Now the supercharger belt squeeks loudly. Doesn't do the start-up squeel, just a steady piercing squeek for at least 5-10 minutes before gradually quieting down. The belt is almost new. Any suggestions? Thanks.
  2. #2 Re: Problem After Dealer Recall Performed
    they take the belt off when the coil bracket comes off. maybe the belts not on the balancer all the way?
  3. #3 Re: Problem After Dealer Recall Performed
    GTP Level Member buickman104's Avatar
    NYC
    Sounds like a PCV issue I had. I thought it was the belt too.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Problem After Dealer Recall Performed
    Apr 2014
    Utah
    The belt looks like it's in place. Just to check, I sprayed the belt with water mist while it was running. The belt went quiet for a couple of minutes until it dried off. I'll check the PCV too this weekend.
  5. #5 Re: Problem After Dealer Recall Performed
    Bad new belt or the tensioner is worn out.
  6. #6 Re: Problem After Dealer Recall Performed
    Topeka, KS
    I'm betting a tensioner pulley
    Sent from my VS990 using Tapatalk
  7. #7 Re: Problem After Dealer Recall Performed
    Nov 2015
    WI
    The tensioner pulley is removed during the recall i would start there and make sure it was installed and torqued correctly.
  1. just had 15757 Under hood fire recall performed
    By GTPNovak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2016, 11:29 AM
  2. Performed broken spring fix on HUD, still nothing?...
    By rizer in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2013, 04:59 PM
  3. Questions about Transmission Cooling, Worth it on stock or wait until mods performed?
    By Mad Max in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2012, 02:28 PM
  4. should I take my car to the dealer for the oil recall?
    By thebone79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2011, 04:44 PM
  5. Work performed over the last two days
    By FuglyGTP in forum General Tech Discussion
    Last Post: 08-30-2010, 10:41 AM
