Thread: ss intercooler lim mods
Results 1 to 20 of 23
  1. #1 ss intercooler lim mods
    Nov 2016
    sheridan
    just picked up a ss intercooler for a smokin deal, has upgraded dual pass heat exchanger, do i need to mod the lower intake to use it, from what i can tell it has all the passages needed to run without doing any surgery to the lower intake
  2. #2 Re: ss intercooler lim mods
    you dont have to. but cutting open the lim to match the ic core is what most do.
  3. #3 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    i figured for 200 bucks for everything i could not pass it up. and later i can swap out to a fullsize core
  4. #4 Re: ss intercooler lim mods
    as long as the fmhe is large enough, the thin one that comes with the zzp ssic kit will get warm. you'l want a larger one like a frozen boost 101 fmhe. hell id run one with a ssic too. the bigger the more coolant it holds and the better it should cool things.
  5. #5 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    it has the bigger dual pass heat exchanger.
  6. #6 Re: ss intercooler lim mods
    nice. you'll also want to plug the two coolant ports and ditch the egr while your at it.
  7. #7 Re: ss intercooler lim mods
    if you got one like this, you should make this bar to mount it with. bit hard to see but the ends are capped, drilled and tapped for a bolt. one end has the bolt in it. fits between th erad support. drill two holes to bolt through, then driill two holes at the bottom to mount the bottom tight.
    folder full of install pics. you also need to cut the hood latch, i welded the top 1/2 to the bar thats holding the fmhe. what that L bracket was for originally.
    http://s1097.photobucket.com/user/sc...?sort=3&page=1
  8. #8 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    you sent me the tunes lol. i have blockoff plates to get rid off all the egr stuff but i was wondering if the SES light would still come on after i remove the actual valve and all the crap that goes with it
    i did plan on making a nice bracket to mount the heat exchanger to.
    and yes i was going to plug the coolant holes 1/4 npt and a flush plug
  9. #9 Re: ss intercooler lim mods
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    If you completely remove the egr then yes it will throw a code.
  10. #10 Re: ss intercooler lim mods
    Quote Originally Posted by 01Blackgtp View Post
    unless they are tuned out, and they are.
  11. #11 Re: ss intercooler lim mods
    Topeka, KS
    ^^ BaZinGa
    Sent from my VS990 using Tapatalk
  12. #12 Re: ss intercooler lim mods
    Quote Originally Posted by rynoman03 View Post
    ^^ BaZinGa
    ive sent out so many tunes i cant keep track of em any more. lol
  13. #13 Re: ss intercooler lim mods
    Topeka, KS
    I'm doing my Lim gaskets today. Woohoo.
  14. #14 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    I planned on after I get everything running and working to mount a tank in the trunk as a reservoir to help keep temps as level as possible and mount 2 small 7 inch fans on the exchanger to help also
  15. #15 Re: ss intercooler lim mods
    if yours looks like mine, 3 inch thick and you dont want it hitting parking blocks and the ground when going in and out of driveways, your not getting fans on it.
    i got mine tucked up behind the bumper some, when they drop lower then the bottom of the rad support it looks like a buck tooth lol
    the radiator fans actually do pull air through the fmhe too
  16. #16 Re: ss intercooler lim mods
    and theres this style, id not mount it like this if it was mine, its too low for one and theres not much supporting it. http://www.grandprixforums.net/threa...BS-Intercooler
  17. #17 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    im pretty sure after looking that its a w body store heat exchanger mine looks exactly like theirs does not sure if that's good or bad lol im sure its better than no intercooler
  18. #18 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    ok figured out im missing all the bolts for the blower anyone know the lengths and size of the bolts I need for a 1inch core ??
  19. #19 Re: ss intercooler lim mods
    did you get injector spacers too? if not you need them, or a zzp rail or custom rail, or logs.
  20. #20 Re: ss intercooler lim mods
    Nov 2016
    sheridan
    I have injector spacers, only thing im missing is the longer bolts for the blower
  1. Intercooler core, intercooler parts. Bonneville SSEi parts.
    By oldsman105 in forum For Sale - Parts
    Last Post: 03-23-2016, 04:59 PM
  2. Intercooler lower intake manifold without intercooler
    By GPChief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 02:35 PM
  3. Want to run an intercooler but not sure of supporting mods
    By camaromattcaddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2014, 09:00 PM
  4. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  5. Fuel rail mods for intercooler?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 11:15 AM
