Thread: Oil pressure concern
Results 1 to 14 of 14
  1. #1 Oil pressure concern
    Nov 2015
    Monroeville, Pa
    Some of you know that I had a piston ring issue recently on my rebuild. Its all fixed now, not burning oil anymore however.... I am now having way lower than normal oil pressure hot at idle. I even used a mechanical gauge to double check it. I have the zzp oil volume kit installed on it and at idle im getting almost 0 oil pressure. I reused the rod bearing when I had the piston/rod out recently. Didn't seem necessary to replace when I had no bearing problem. Cold oil pressure is only at 50. Before this piston ring problem I had about 65-70 psi at cold startup and about 15-20 at hot idle. When I snap the throttle after warm idle this is an audible rattle sound coming from the engine which I know is not good. I even took the superchager belt off just to make sure it wasn't rotor rattle. Any ideas? Thank you very much I cannot tell you guys how frustrating this whole rebuild has been with problem after problem. Ive heard from alot of people that you should not rebuild these engines and im really starting to believe that.
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #2 Re: Oil pressure concern
    around 20 psi hot at idle is rather normal. but the rattle part is not. i'd hoping for a flex plate issue of some kind.
  3. #3 Re: Oil pressure concern
    Mar 2012
    NC
    I would check the oil pressure relief in the oil filter housing. It might have gotten stuck due to high oil pressure or metal from the rebuild.
  4. #4 Re: Oil pressure concern
    Quincy, Mass
    You should probably get a used block and replace that one.
    No more GP 04 Impala SS Indy:
  5. #5 Re: Oil pressure concern
    Nov 2015
    Monroeville, Pa
    I was starting to think the same thing...
  6. #6 Re: Oil pressure concern
    GTP Level Member
    Pittsburgh
    if you had good Pressure before and not so great after WITH the rattle, I think its time for a shortblock. Good thing our area has a ton of 3.8's hanging out in the junkyards
    2003 SSEi,
  7. #7 Re: Oil pressure concern
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    That sucks, considering how much you put into that block...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #8 Re: Oil pressure concern
    Nov 2015
    Monroeville, Pa
    I just don't understand what happened all I did was take the piston and Rod out in the cylinder put a new set of rings on that piston and now it has low oil pressure nothing else has changed
  9. #9 Re: Oil pressure concern
    Quincy, Mass
    My guess is because you reused the rod bearing, probably the rattle you hear now too.
  10. #10 Re: Oil pressure concern
    Nov 2015
    Monroeville, Pa
    The rattle is only after the engine gets to operating temp and when the throttle is swatted real quick. I put 10w40 oil in it today and the warm idle pressure was up to 25 now instead of basically 0. Im wondering if I should put a new bearing in that rod. No bearings spun yet so thats good.
  11. #11 Re: Oil pressure concern
    Bastard Reptile's Avatar
    Kansas City, MO
    Did you replace the oil pump? When you rebuilt the engine, did you remove the balance shaft? I'd also check that relief valve. Can't hurt.
    The rattle, to be honest, is likely a rod or two knocking. AKA, spun (or not quite yet spun) rod bearing.
  12. #12 Re: Oil pressure concern
    Nov 2015
    Monroeville, Pa
    The oil pump is new and yes I remove the balance shaft and drilled tapped and plugged the oil hole for the shaft. I drop the oil pan last night and took off the number 3 rod bearing cap and the bearing is all way down to the Copper already I'm not really sure what has happened to this engine I had all the machine work done and everything was inspect when I measured when assembling. I'm going to try to replace all the rod bearings and see how that goes none of the bearings have spun yet and the crank still looks good. If I still have a problem I'm just going to buy another engine because this once cursed LOL
  13. #13 Re: Oil pressure concern
    rebuilds are hit or miss, even with all proper machine work being done. i vote used engine now. cause this one will only be an issue.
  14. #14 Re: Oil pressure concern
    Kansas City, MO
    Careful....if a rod bearing gets too out of whack, it could cause the rod and cap to become stretched, or out of round.
  1. transmission compatibility concern
    By synysterjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2013, 11:49 AM
  2. Over-Drive Concern
    By brandonl2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2012, 02:52 PM
  3. NEWBIE with concern 2004 GTP
    By lobos in forum Introductions/Noob Questions
    Last Post: 10-19-2010, 12:29 AM
  4. Hey just a concern
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-15-2010, 02:41 PM
