Some of you know that I had a piston ring issue recently on my rebuild. Its all fixed now, not burning oil anymore however.... I am now having way lower than normal oil pressure hot at idle. I even used a mechanical gauge to double check it. I have the zzp oil volume kit installed on it and at idle im getting almost 0 oil pressure. I reused the rod bearing when I had the piston/rod out recently. Didn't seem necessary to replace when I had no bearing problem. Cold oil pressure is only at 50. Before this piston ring problem I had about 65-70 psi at cold startup and about 15-20 at hot idle. When I snap the throttle after warm idle this is an audible rattle sound coming from the engine which I know is not good. I even took the superchager belt off just to make sure it wasn't rotor rattle. Any ideas? Thank you very much I cannot tell you guys how frustrating this whole rebuild has been with problem after problem. Ive heard from alot of people that you should not rebuild these engines and im really starting to believe that.
