Thread: 97 Tail lights different?
Results 1 to 8 of 8
  1. #1 97 Tail lights different?
    Sep 2014
    Las vegas
    My tail lights on my 97 gtp coupe are in need of replacing, I order some spyder led tail lights. Everyone seems to like them and they look pretty good, however I wasn't able to get them to fit on my car the body of the tail light hits the body of the car before the tail light goes in all the way. It has to go in about another inch and a half before its in properly (yes, the 3 tail lights studs line up in the holes and go in) . I couldn't find anything anywhere about anyone else having this fitment issue with these taillights
    I have 2 97 gtp coupes one with a build date of 11/96 and one 2/97 and its the same thing for both. Did anything change for the body around the tail light for the 98 and up years?
  2. #2 Re: 97 Tail lights different?
    The body is still the same, nothing on the outside for the tail lights changed.
    I'd email the vendor and tell them about the issue and see what they have to say.
  3. #3 Re: 97 Tail lights different?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Mine were tight to i had to ream the holes out where the studs go in and they fit really good. I've had them on the car for years with no issues.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: 97 Tail lights different?
    GTP Level Member buickman104's Avatar
    NYC
    Yup, you have to ream the holes with a file to make them fit properly. Almost nothing from Spyder fits properly on our cars.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: 97 Tail lights different?
    Sep 2014
    Las vegas
    what exactly do you mean ream?
  6. #6 Re: 97 Tail lights different?
    Jul 2015
    Jamestown, NY
    I took a drill bit that just barely fit through the holes already there and wobbled the drill around to make the holes slightly bigger. It was still a tight fight it helps to grab the stud and pull it while pushing on the taillight at the same time. You will actually hear the threads of the studs click as they go by the sheet metal when you push it in.
  7. #7 Re: 97 Tail lights different?
    NYC
    I used a cheap $2.99 thin file from home depot to widen the holes. Make sure to put a little paint over the widened holes to help prevent rust.
  8. #8 Re: 97 Tail lights different?
    Sep 2014
    Las vegas
    Yep, thanks for the advice i used a drill and slightly enlarged the holes as well as widened them towards the outside of the car so i have room for adjustment once i put the tail light in, after that got it lined up nice and put the 3 plastic hand screws back in and once i tightened them up that pulled the tail light right in and it was pretty much perfect.
  1. PRICE DROPS! 04+ tail lights! TAIL LIGHTS!!!!!
    By Kejross in forum For Sale - Parts
    Last Post: 06-12-2014, 10:04 PM
  2. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
