Thread: Rebuilding after chipping a piston. Need advice.
Results 1 to 9 of 9
  1. #1 Rebuilding after chipping a piston. Need advice.
    Aug 2016
    st paul, mn
    Hey guys, i need help on parts for this l67 rebuild.
    First off, I'm boring the block .020" over and will get the rotating assembly balanced. I'm using stock crank. I need help on rod/ piston selection. I'll be running an s1x cam, 1.8 rockers, e85, and an intercooler. I'm looking for around 300 fwhp. Last dyno on the stock cam, 1.8 rockers with a 3.2 was 236 whp, 346 wtq.
    Having said that, can i safely do some 9.4:1 hypereutectic pistons with n/a rods? I'll be running a 3.4 pulley on first startup. I'm looking at keith black pistons. Advice is greatly appreciated, however know I'm not spending the money on forged.
  2. #2 Re: Rebuilding after chipping a piston. Need advice.
    Omaha, NE
    Those pistons should be fine. You could probably get away with stock rods, but since you're already in there upgrading, you might want to consider H beam rods. They'll be much stronger than stock.
    ZZP has some for $600 a set, or you can probably get some good ones on eBay for around $200. The sloppy mechanics use ebay internals on high hp LS builds pretty often.
  3. #3 Re: Rebuilding after chipping a piston. Need advice.
    Make sure they do the whole nine yards to this engine and I mean everything because I'd say about 90% of rebuild 3800's blow up within the first 1,000 miles. It would be cheaper to just source a stock NA block unless you can get the machine work for some killer deal.
  4. #4 Re: Rebuilding after chipping a piston. Need advice.
    Antioch, IL
    machined engine for 300hp? LOL boy go buy a used block and drop it in.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Rebuilding after chipping a piston. Need advice.
    Quote Originally Posted by whitetrashgtp View Post
    Those numbers seem pretty low to me, even for having a stock cam.
  6. #6 Re: Rebuilding after chipping a piston. Need advice.
    Aug 2016
    st paul, mn
    A local reputable machinist near me who has done a few 3800's before told me he'd blueprint/balance everything for 600 bucks with the .020" over bore. I only trust him because my work has 2 loaner cars with their rebuilt 3800 in it. However, i kind of have to assume a lot of rebuilt blow ups are due to poor break in.
  7. #7 Re: Rebuilding after chipping a piston. Need advice.
    no, they blow up due to crappy machine shop work, or none at all. there is no break in for a modern engine with a roller cam.
    i would so save 2 grand and find a used engine.
  8. #8 Re: Rebuilding after chipping a piston. Need advice.
    SWPA
    This comment proves you have zero idea what a break in actually breaks in. The only thing that needs broken in is the rings. That's it. If the rings don't seat then the car will still run, but just smoke and be down on compression.
  9. #9 Re: Rebuilding after chipping a piston. Need advice.
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Most rebuild failures on these are from the mains not getting line bored, and people reusing there rods with oblonged big ends.Basicly, bearing spin city. You get your machine work done properly, use aluminum bearings and you should be ok. I have 18k on my rebuild in my 5 speed gtp.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  1. S/C seized up, rebuilding snout, need advice
    By BlackGTP01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2014, 08:09 PM
  2. Scratch and paint chipping under rear plate
    By Linebacker in forum Visual/Body Modifications
    Last Post: 05-19-2012, 09:33 PM
  3. Paint Chipping
    By Points70 in forum Visual/Body Modifications
    Last Post: 04-16-2012, 09:55 PM
  4. Chipping paint and rust under the stock spoiler
    By GtpKo in forum Visual/Body Modifications
    Last Post: 11-27-2009, 04:00 PM
  5. Chipping a no no?
    By Pontiac Warrior in forum General Tech Discussion
    Last Post: 05-15-2009, 07:11 PM
