Thread: just had 15757 Under hood fire recall performed
Results 1 to 11 of 11
  1. #1 just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    Has anyone else had this done? They replaced the font valve cover with a new black one. The rear one on my GTP is grey. So now i have mismatched valve covers. Anyone else experience this?
  2. #2 Re: just had 15757 Under hood fire recall performed
    everyone. thats all they offer is a new black one. cant hardly see the back one any ways.
  3. #3 Re: just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    Just making sure. They also informed me my LIM and oil pressure sensor was leaking and needed new gaskets. They said it would be $853 i said no. I usually do all my own work the only reason it went in for the recall was to have the documentation.
  4. #4 Re: just had 15757 Under hood fire recall performed
    850, thats criminal. one day il go for the recall myself. they wont just hand it over, they need to put it on.
  5. #5 Re: just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    Decided to check for the coolant leak on my LIM the tech stated he found during the recall work. Sure enough there is coolant pooled on the front part of the LIM, never saw it before but was never looking for it either. I am wondering if the work / impact gun might have made the crappy gasket finally give up? In the photo you can see coolant pooled on the LIM and around the injector.
    http://i1042.photobucket.com/albums/...ps1yeu1cqe.jpg
    http://i1042.photobucket.com/albums/...pswojjt67q.jpg
    Looks like i will be ordering parts and replacing the gasket. I watched the how to video the Dave "DuBob" Richie posted and feel like this is something i can do in the garage.
    https://drive.google.com/file/d/0B5O...l=en_US&pli=1#
    I plan to fully flush the dexcool out and replace with regular coolant, new thermostat, new AL elbows, and of course new gaskets.
    I might do higher ratio rockers / maybe springs.
  6. #6 Re: just had 15757 Under hood fire recall performed
    that looks odd, when the bolts leak the whole valley there fills with coolant and covers the bolt. thats coolant on the injector.
    get the mangum lim kit off rockauto, you wont find it cheaper anywhere else.
  7. #7 Re: just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    I cleaned it all up last night to see if it leaked or it was "spilled" on the engine after they tried to get me to pay a crazy amount for the gasket change. I will check tonight when i am home from work.
  8. #8 Re: just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    Is this the kit you are talking about? MAGNUMMS18144 Premium Molded Rubber on Steel Carrier
  9. #9 Re: just had 15757 Under hood fire recall performed
    likely. its metal just like the delco or felpro, but only 40 bucks and comes with way more things.
  10. #10 Re: just had 15757 Under hood fire recall performed
    Nov 2015
    WI
    Its definitely leaking. The GTP will be parked until i get the parts time to work on it.
  11. #11 Re: just had 15757 Under hood fire recall performed
    Quincy, Mass
    You can have certified mechanic do it then they have gm pay them, so you can do it yourself if you have a buddy with a shop.
    No more GP 04 Impala SS Indy:
  1. Another GM recall for 3800 engine fire
    By MM704 in forum General Grand Prix Discussion
    Last Post: 02-28-2020, 04:24 AM
  2. 3800 Engine fire recall details
    By Impala131 in forum General Grand Prix Discussion
    Last Post: 12-22-2015, 11:41 AM
  3. Latest Recall 09047 Engine Compartment Fire
    By Pontiacmaster81 in forum Off Topic Discussion
    Last Post: 09-23-2014, 08:23 PM
  4. Recall 07035 engine fire "warning"
    By chuckd98gtp in forum The Rant Forum
    Last Post: 07-06-2011, 01:35 PM
  5. The Engine Fire Recall?
    By Importz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-11-2011, 07:23 PM
