Thread: snout plug
Results 1 to 3 of 3
  1. #1 snout plug
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Hey, I swapped out my pulley today and the plastic plug in the end of the s/c snout came out in peices. Should I replace this? What is its purpose? Also I must give a to ZZP for the design of the Gen 2 puller. It made this task so much easier!
  2. #2 Re: snout plug
    Feb 2009
    canada
    I put a x-mas tree plug back in so hopefully that will be ok... is it possible for the s/c oil to leak from this hole if no plug was there??
  3. #3 Re: snout plug
    Wichita, KS
    If you had a plastic plug in there before, then you can use anything you want to seal the hole...or leave it open does not matter, it is not a seal of any sorts, cause your snout shaft is not "vented". It just keeps dirt and crap from getting down in the threads.
    The earlier snouts that had a "breather" bolt/plug in them had a vented snout shaft to release pressure that built up in the case. THESE snouts do require that plug, putting in a plastic "Christmas Tree" plug will only allow the oil to seep out, and get everywhere...even worse.
    And no...having a vented to a non vented snout shaft is not better. There is no real advantage to one over the other.
    ~F~
  1. Removing Supercharger Snout Oil
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 10-05-2012, 01:56 PM
  2. leaking s/c snout?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 07:47 PM
  3. Can i flip my snout around
    By Merlin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 02:31 PM
