its worth is. even with the ic on there. guy in NC has about the same mods, he said the cars a whole new animal on e85. hes a gen 5 blower n* 1.95 rockers. hes up to 18º timing fsic and a 3.0 iirc. or one up or down from there.
you will want to have a tuner on hand for the swap. canned tunes dont always fair well. not sure if many places will even do a canned e85 tune either. you need like 60 lb injectors too. you can set them up for gas, and e85 and either have two pcm's or flash the tune back and forth as needed should you have to run gas again.
