Thread: Sounds like a flexplate noise, if so pulling Eng/Trans
Results 21 to 40 of 70
  1. #21 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    That's pretty chewed up in there... Lol
    At least you know what it is... While the engine is out you can get a full re-gasket kit in it, with that it'll last for another 200k. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #22 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    I know you said low budget, but do what you can while it is all out...
    Much easier, as you would expect, to work on stuff while it's out...
    Atleast entertain a timing chain, crank seal (both sides of crank/rear main), cam/lifters, misc gaskets...
    4-500 more in parts is worth the time you spent pulling the "nugget" out...
    Come out ahead in the long run...
    Oil pan gasket at a minimum!!
  3. #23 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    SE Level Member Stoenr's Avatar
    Aug 2015
    Chicago Burbs
    Oil pan gasket was done over last winter, hopefully shes good, lol.
    Not putting 400-500 into this car. Just glad the flex plate and 8 bolts only cost me(well my son) 72 bucks out the door.
    I do have the oil filter housing gasket as I think that might be leaking, and also heard it helps a little to remove prior for more wiggle room.
    I figure why not replace the water pump and gasket while its out.
    I had him purple power the crap out of the motor to clean up the oil thats made its home there. (he said it looks like new now)
    Going to add some leak dye to it, run it for a bit. Then when its out, inspect for whats leaking, and take care of it.
    I suspect the rear main housing gasket to be leaking. I hear the actual rear main seals usually do not leak, but the housing is the culprit.
    In case the actual main seal is leaking, does this require special tools to remove, and install? I seen an install tool for it and it was like 500 lol (OTC brand) No thanks.
    Ford Guy, Kids the GP guy.
  4. #24 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    rear cover comes right off, locktite the little bolts and snug them up good. rtv the pan and both sides of the bottom 2 inches of gasket for the rear cover.
  5. #25 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Dec 2012
    troll land
    make sure to go with acdelco wp
  6. #26 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Aug 2015
    Chicago Burbs
    Yeah, I read that on one of the threads, but just curious if the actual crank seal is a pain, or requires special tools to remove or install?
    Also the front timing cover is that going to be an issue if ends up needing a new gasket?
    Engine coming out in the next day or two, liked to be prepared. I think Ive spent more time reading up on the how too's than the time it will actually take to do the job, lol.
  7. #27 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    seal is easy, 2 2x4's, lay the cover over them so the seal is in the clear and tap it out with a hammer. flip it over and tap in the new seal.
  8. #28 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Dec 2012
    troll land
    Quote Originally Posted by Stoenr View Post
    not a bad thing
  9. #29 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Aug 2015
    Chicago Burbs
    Awesome, thanks!
    Quote Originally Posted by l67ss View Post
    not a bad thing
    I remember the day I came here just a little over a year ago looking to buy this car asking questions, here I am now stuck pulling a motor, lol.
  10. #30 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    no one comes with intentions of pulling a engine, but a little coaxing later, its happening. i for one never thought id be pulling my engine, and i did.
  11. #31 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Antioch, IL
    Drain the boys bank account and throw mods on it LOL
    2009 Challenger SRT8
    Expert at being gay.
  12. #32 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Kemmerer, Wyoming
    when you change the crank seal, don't get one from carquest. I did, and it failed within 50 miles. the one from gm cost the same, and has held up since it was installed about 2 years ago.
  13. #33 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Aug 2015
    Chicago Burbs
    Quote Originally Posted by ItHurtz View Post
    He has no problem doing that on his own. Against my opinions. 17 year old, lives with his mom, goes to school and has a part time job. Stop spending everything you make on modding the car, you need to save to fix it or when it breaks!
    Mods, smaller pulley, tune, headers, hot air intake, tint projector headlights, only because factories were fogged to all hell.
    Repairs, trans mount, engine mount, both axles, oil pan gasket, rear brakes, fuel lines from filter to engine, sway bar during the flex plate job since bar is cracked.
    I may have missed something, but you see where I am going.
    PS. Im sure I will be back with needing help during this job.
  14. #34 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Kemmerer, Wyoming
    doing a set of F body brakes on the front would be a good mod as well. it's almost criminal how pathetic the oem brakes are compared to the F body brakes from the 2000 ish camaro.
  15. #35 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Antioch, IL
    Being 17, he should be saving for a trans next!
    Where in the burbs are you
    screw fbody, 06+ impala are direct bolt on
  16. #36 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Oct 2014
    Frederick, MD
    Dual piston FTW! And I would consider projector HIDs a safety concern kind of mod... Light output is terrible stock, and being able to see at night is a necessity.
  17. #37 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Aug 2015
    Chicago Burbs
    Im far south, Oak Forest, work up in Rolling Meadows, sons in NW Indiana
    Quote Originally Posted by WarStryker13 View Post
    No more modding please! lol Cars just to old, and the salt belt hasn't been to nice to it.
    I just want him to keep it running decent, and make it last a bit longer
    HID's done. such a difference for sure!
    http://www.06gt.com/GrandPrix/GTPHID.jpg
  18. #38 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Sacramento, CA
    I've heard of the front timing cover cracking upon tightening down...
    Just use the torque spec and you should be ok (change timing chain and cam)
    lol
  19. #39 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Do what I did.. drain coolant, yank engine, swap flexy, lower back in, fill it back up with coolant and smile for your 3 hours of work while calling it a coolant swap. lol
  20. #40 Re: Sounds like a flexplate noise, if so pulling Eng/Trans
    Aug 2015
    Chicago Burbs
    Shes out!
    The flex plate actually rotated about 3/4 " from the center hub! how was it even still on and running is beyond me!
    It was rubbing on the case housing, other than a little worn off metal, i think it will survive? Opinions?
  1. Pulling motor from trans, still in car.
    By 97Darktealgp in forum Engine
    Last Post: 09-04-2016, 10:11 PM
  2. ...So pulling out the engine & trans
    By krysp432 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2015, 12:57 PM
  3. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  4. Anyone replaced a flexplate without dropping cradle or pulling engine?
    By Damnir in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2013, 11:32 AM
