Thread: Unique-ish Cooling Issue on my GTP?
Results 1 to 20 of 65
Threaded View
sambroom Unique-ish Cooling Issue on... 09-01-2016, 12:05 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 12:10 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 12:12 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 12:12 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 12:35 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 12:42 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 12:57 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 01:03 PM
idrivejunk Re: Unique-ish Cooling Issue... 09-02-2016, 08:28 AM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 01:50 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 01:59 PM
idrivejunk Re: Unique-ish Cooling Issue... 09-02-2016, 09:07 AM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 02:21 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 02:26 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 02:32 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 02:49 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 02:53 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 06:07 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 06:18 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 06:45 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 06:50 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 06:56 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 06:58 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 07:03 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 09:10 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 09:36 PM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 07:50 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:11 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:21 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:32 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:19 AM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 09:22 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:28 AM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 09:35 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:39 AM
sambroom Re: Unique-ish Cooling Issue... 09-05-2016, 08:01 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 09:40 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 09:48 AM
stocker Re: Unique-ish Cooling Issue... 09-08-2016, 10:26 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 10:31 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 10:32 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 10:34 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 10:50 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 05:21 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 05:57 PM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 07:30 AM
markpa Re: Unique-ish Cooling Issue... 09-09-2016, 09:42 AM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 11:33 AM
WarStryker13 Re: Unique-ish Cooling Issue... 09-09-2016, 11:15 AM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 11:30 AM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 05:43 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 05:47 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 06:16 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 06:39 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:06 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 10:15 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:26 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 10:49 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:52 PM
sambroom Re: Unique-ish Cooling Issue... 09-12-2016, 09:27 AM
sambroom Re: Unique-ish Cooling Issue... 09-12-2016, 05:10 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-12-2016, 05:18 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-12-2016, 05:54 PM
sambroom Re: Unique-ish Cooling Issue... 09-13-2016, 08:23 AM
sambroom Re: Unique-ish Cooling Issue... 09-13-2016, 04:33 PM
  1. #39 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    I think it burped. I took it for a drive last night. It was about 70 degrees out, so cooler than other times I have tested it. However, I was able to make it up the pass I was trying to do before. The temps held at about 208 as long as I kept the speed up to 35-40mph. When I stopped a few times and started up again, the temps would climb to 217 and then slowly come back down to around 208. I find these temps for a mountain climb to be acceptable, but I still have reservations since it was dark and 70 degrees out instead of sunny and 100. It should be sunny and 85 degrees today, so I'll try it again and see if I get similar results.
  1. Cooling issue
    By ZSharp1985 in forum Introductions/Noob Questions
    Last Post: 04-08-2015, 09:24 PM
  2. Cooling issue help
    By ItaliaGTP35 in forum General Grand Prix Discussion
    Last Post: 04-12-2014, 11:15 AM
  3. Another cooling issue. '98 N/A 3.8
    By harner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2013, 09:51 AM
  4. Cooling Issue
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 06:51 AM
  5. unique idle issue
    By 02bluegtss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2010, 12:36 PM
