water pump and LIM gaskets are your main concerns, you will want to change out the coolant elbows for aluminum while you're in there. You should do a flush as well, there's still probably some sludge lurking around in there somewhere.
And the factory front manifold sucks balls, rear is tubular instead of cast iron. and headers can cost up to $850+ for good ones.
