Fans... Both come on when the AC is on. Not sure if low or high. Both also come on when the temp (from the scanner) is about 226. Again, not sure if low or high. I heard they are supposed to come on earlier. I'll mess with it a bit today to get more detailed info.
I'll also clean the radiator real good to cover my bases. I looked at it before and it didn't look too gummed up... I'm betting there is a blockage in the cooling ports somewhere in the engine. I suppose there just has to be... No air in the system, water pump is good, no heating core or elbow leaks (replaced elbows with aluminum when I checked the water pump), and I think the fans are working the way they should be... Unless they come on too late for some reason.... Even so, when I go up a hill, the temp keeps on rising with the fans on.
