Thread: Unique-ish Cooling Issue on my GTP?
Results 21 to 40 of 65
sambroom Unique-ish Cooling Issue on... 09-01-2016, 12:05 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 12:10 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 12:12 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 12:12 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 12:35 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 12:42 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 12:57 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 01:03 PM
idrivejunk Re: Unique-ish Cooling Issue... 09-02-2016, 08:28 AM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 01:50 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 01:59 PM
idrivejunk Re: Unique-ish Cooling Issue... 09-02-2016, 09:07 AM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 02:21 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 02:26 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 02:32 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 02:49 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 02:53 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 06:07 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 06:18 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 06:45 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 06:50 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 06:56 PM
WarStryker13 Re: Unique-ish Cooling Issue... 09-01-2016, 06:58 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-01-2016, 07:03 PM
sambroom Re: Unique-ish Cooling Issue... 09-01-2016, 09:10 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-01-2016, 09:36 PM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 07:50 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:11 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:21 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 08:32 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:19 AM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 09:22 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:28 AM
sambroom Re: Unique-ish Cooling Issue... 09-02-2016, 09:35 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-02-2016, 09:39 AM
sambroom Re: Unique-ish Cooling Issue... 09-05-2016, 08:01 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 09:40 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 09:48 AM
stocker Re: Unique-ish Cooling Issue... 09-08-2016, 10:26 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 10:31 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 10:32 AM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 10:34 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 10:50 AM
sambroom Re: Unique-ish Cooling Issue... 09-08-2016, 05:21 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-08-2016, 05:57 PM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 07:30 AM
markpa Re: Unique-ish Cooling Issue... 09-09-2016, 09:42 AM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 11:33 AM
WarStryker13 Re: Unique-ish Cooling Issue... 09-09-2016, 11:15 AM
sambroom Re: Unique-ish Cooling Issue... 09-09-2016, 11:30 AM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 05:43 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 05:47 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 06:16 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 06:39 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:06 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 10:15 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:26 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-11-2016, 10:49 PM
sambroom Re: Unique-ish Cooling Issue... 09-11-2016, 10:52 PM
sambroom Re: Unique-ish Cooling Issue... 09-12-2016, 09:27 AM
sambroom Re: Unique-ish Cooling Issue... 09-12-2016, 05:10 PM
Fivefingerdeathpunch Re: Unique-ish Cooling Issue... 09-12-2016, 05:18 PM
Scottydoggs Re: Unique-ish Cooling Issue... 09-12-2016, 05:54 PM
sambroom Re: Unique-ish Cooling Issue... 09-13-2016, 08:23 AM
sambroom Re: Unique-ish Cooling Issue... 09-13-2016, 04:33 PM
  1. #1 Re: Unique-ish Cooling Issue on my GTP?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    You could use a pry bar to angle the engine forward slightly, if you disconnect the front dogbones you can get it even further.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #2 Re: Unique-ish Cooling Issue on my GTP?
    Un bolt the dog bone mounts, then ractchet strap the motor forward. That should give you another 2-3in maybe.
  3. #3 Re: Unique-ish Cooling Issue on my GTP?
    Oct 2014
    Frederick, MD
    ratchet strap works too, so you don't have to hold the prybar and try to thread a hole...
    I tend to do things the hard way, my apologies. lol
  4. #4 Re: Unique-ish Cooling Issue on my GTP?
    socket and a 3 inch extension to a ratchet works like a charm.
    the plug blocked by the o2 sensor, slide the socket on the plug, then you can get 1/2 the tip of the extension in the socket and crack it free. or use a open end wrench on the spark plug socket you should be using.
    un bolt the dog bones from the engine, pass side coil bracket has two holes in it, put the bolt in the dog bone pull the engine forward and put the bolt in the other hole in the bracket, this gives you 2 inches of room.
  5. #5 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    thanks for the strap idea. My biggest issue was being able to turn the tester hose to thread it in. I wised up and made a duct tape 'handle' at the top of the hose to give myself more turning power. So I got all the numbers now:
    1: 120 dry, 135 wet
    2: 145 dry
    3: 125 dry
    4: 120 dry, 145 wet
    5: 130 dry
    6: 145 dry
    so per head I have:
    front 120, 125, 130
    back 145, 120, 145
    I retested the two lowest cylinders wet as well to help determine if piston rings might be more to blame... Maybe?
    the biggest margine is about 17% on the back head.
    Is this a cause for concern for the heads?
    and the big question: Am I going to want the build this one?
    I didn't get around to the water pump yet (pending my decision on whether or not to sell), and the LIM has the black stock gaskets, though I didn't see any puddles around the LIM bolts. A bit of grime, but not puddles.
  6. #6 Re: Unique-ish Cooling Issue on my GTP?
    Compression seems alright, is it perfect no but it's not going be a huge cause for concern in my eyes.
    People throw down 300+ whp in 200K mile blocks they snag from the junkyards. If it's got a solid bottom end and the pistons ain't chipped it's a good running engine to me.
  7. #7 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    I hope the bottom end is solid enough, though piston rings seem like they might be an issue on at least cyl 4, since the wet test compression was so much higher.
    Also, when I went for a shakedown drive after replacing the plugs last night, I found another top-engine noise that didn't go away after warmed up. Coming from the injector area for sure, but seems loud for injectors. Maybe I never noticed it before because you cant really hear it with the hood shut. Here is a link to the sound: https://www.youtube.com/watch?v=3u6gBWBFc1Y
  8. #8 Re: Unique-ish Cooling Issue on my GTP?
    it kinda sounds like every other 3800 lol they all tick and makes sounds that would make you concerned.
  9. #9 Re: Unique-ish Cooling Issue on my GTP?
    mines got some ticking going on, i got roller rockers and new ish springs, and 42 lb injectors and had just had them all in my hands and reinstalled on this new engine. its all pretty normal sounding to me at this point lol
  10. #10 Re: Unique-ish Cooling Issue on my GTP?
    i dont even notice it no more. i pop the hood and fire it up and people are like its so quiet, then if they see the headers they are like are those HEADERS? its so quiet lol
    roller rockers are tick monsters for sure. the 42's might tick louder then stock too.
  11. #11 Re: Unique-ish Cooling Issue on my GTP?
    i think that was the 3.0 pulley over winter time, ic was just installed. you need to play a little bit right, sc takes on all sorts of sucking and whining sounds with the little pulleys.
  12. #12 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    Geez, I just looked over your mods. She get up and go Scotty?
  13. #13 Re: Unique-ish Cooling Issue on my GTP?
    some what lol its way better feeling then stock of course, my best track pass was a 14.3, so ive lowered the shift points hoping it gets me into the hi 13's. thinking the wasted extra rpms are slowing it down. i only need to find 1/2 a second. that run ws in 90 degree heat, if i can get a cooler day i can turn up the timing.
    i did spank a charger r/t on that 14.3 run lol
  14. #14 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    Nice! Bet that late-model Charger owner loved getting beat by a 98 Regal.
  15. #15 Re: Unique-ish Cooling Issue on my GTP?
    thats my running joke, how his friends will never let that loss go, wtf was that thing anyways?
  16. #16 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    Update on this initial issue:
    I pulled the water pump and it looked fine. No leaking and the blades looked good. No obviouse wear. It wasn't noisy before, so I bet the bearings are ok. I reinstalled it. While I had it out, I sprayed high-ish pressure water into the hoses that go to the heating coils. It pushed plenty of coolant out, but no gunk. I put everything back together, filled and bled (and bled warm multiple times). Then I did my stress test by running the engine at 3,000 RPM in park for a few minutes. Same thing happened, gauge climbed and climbed, fans kicked on around the 210 mark, but the needle kept rising with no sign of slowing down. The purpose of the test is to simulate long slow hill climbing, which there is a lot of here in Utah. I'd say the cooling system is still failing the test. Should I just not expect to be able to hit mountain roads in this car?
    The last thing I can think of that could be causing the cooling issue would be grime/blockage from the LIM gaskets. Does that sound about right? I figure I will do the LIM gaskets soon, at the same time I do the rocker arms, lifters and valve cover gaskets. When I do it, is there any reason I shouldn't try cleaning out all the coolant ports with high-pressure water and compressed air (after blocking off the intakes of course)?
  17. #17 Re: Unique-ish Cooling Issue on my GTP?
    Sep 2016
    Utah
    I'm still trying to figure out if my cooling condition is normal or not. I got the torque app and bluetooth. I have been watching my actual temps for the last two days. Under normal driving conditions (85 degrees outside, on flat surfaces without heavy traffic), my temps sit at 212-215 degrees. Parked at 85 degrees, same thing. In heavier traffic at 85 degrees outside, the coolant temp rose and fluctuated between 220 and 230. I drove one long hill for the sake of testing, and I ended up turning around when the app read 238 degrees, with no signs of leveling off. However, driving to work this morning (a 40 minute drive) it was about 57 degrees outside, and the coolant temp never went above 180. I have a 180 T-stat in there... So I'm wondering, do these actual temps seem normal? Or is it simply running too hot?
  18. #18 Re: Unique-ish Cooling Issue on my GTP?
    that is to hot. 215 ish to 220 is somewhat normal with the stock fan settings. past that id think somethings up.
    make sure both your fans come on with the a/c on. if one is off you might have a bad relay or a bad fan. temp sensor can also mess up the fans. but that usually disables the fans from working 100%.
  19. #19 Re: Unique-ish Cooling Issue on my GTP?
    GTP Level Member
    Aug 2012
    st louis park, MN
    Just a random idea. You could check the condition of your radiator. We once had a crown vic that had a radiator clogged with dirt and dust that couldn't provide enough cooling.
    Also, I heard there are coolant system cleaners you can use to clear out gunk in your system. I suppose you could have some blockage that won't budge with just a system flush with a hose. Could be worth a shot.
    Also, why are you running a 180*? I've read on here numerous times that doesn't help anything unless you have mods and a tune to account for that.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  20. #20 Re: Unique-ish Cooling Issue on my GTP?
    180 t stat is no help especially with the stock fan settings.
    i got my fans tuned to 180 and still run a 195 t stat, i run 195- 210 ish but it holds there, that traffic hot.
    rad cleaning, spray it and the a/c condenser core with de greaser, then hose it out form the fan side out. if its clogged up with dirt and leaves and bugs you'l see the crap coming out.
  1. Cooling issue
    By ZSharp1985 in forum Introductions/Noob Questions
    Last Post: 04-08-2015, 09:24 PM
  2. Cooling issue help
    By ItaliaGTP35 in forum General Grand Prix Discussion
    Last Post: 04-12-2014, 11:15 AM
  3. Another cooling issue. '98 N/A 3.8
    By harner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2013, 09:51 AM
  4. Cooling Issue
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 06:51 AM
  5. unique idle issue
    By 02bluegtss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2010, 12:36 PM
