Unplug the maf see if it's still doing it. Could be a bad maf or even a bad IAC, sounds to me like the intake is sucking in more air than usual. Mine will do it when I first start the car and then settle down after a min or 2. Could be a vacuum leak as mentioned above, I use rtv instead of throttle body and supercharger gaskets to prevent leaks.
