Thread: Is there a 'safe' octane range for our engines?
Results 1 to 7 of 7
Centauri Is there a 'safe' octane... 08-20-2016, 11:58 AM
SgtMarshal Re: Is there a 'safe' octane... 08-20-2016, 12:04 PM
Scottydoggs Re: Is there a 'safe' octane... 08-20-2016, 12:32 PM
SgtMarshal Re: Is there a 'safe' octane... 08-20-2016, 12:43 PM
J57ltr Re: Is there a 'safe' octane... 08-20-2016, 05:35 PM
SgtMarshal Re: Is there a 'safe' octane... 08-20-2016, 05:43 PM
J57ltr Re: Is there a 'safe' octane... 08-22-2016, 12:16 AM
  1. #1 Is there a 'safe' octane range for our engines?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    Just curious.
    Locally, the best stuff available is 91 (or even 90...) with 10% ethanol. Lately I've started adding Royal Purple booster to compensate. But in other markets I know 93 is available. I know going too low can end badly, but what about too high? 93 and the +3 RP booster?
    Just wondering before I ever get myself in a pickle.
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  2. #2 Re: Is there a 'safe' octane range for our engines?
    Kemmerer, Wyoming
    I wouldn't bother with the royal purple octane booster, it is likely just snake oil. if you want to add stuff to raise the octane, get some torco accelerator. it will actually raise the octane legitimately, not like the snake oil type stuff. you would be just fine with premium though. if it was a big issue, the car manufacturers would be going rounds with the gas companies. the highest octane available where I live is 91 as well, and the owners manual dictates premium fuel only.
    edit for link added: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  3. #3 Re: Is there a 'safe' octane range for our engines?
    depends on if you have kr with your mods. if you do running 91 and dont when running 93 you know your tune needs to be adjusted for the 91, aka less timing up top would fix this.
    or get on marshals torco bandwagon.....
  4. #4 Re: Is there a 'safe' octane range for our engines?
    Kemmerer, Wyoming
    I was curious what was in that royal purple to raise the octane, and it's mmt, which is not effective.
  5. #5 Re: Is there a 'safe' octane range for our engines?
    GXP Level Member
    Mar 2015
    Tomball
    I octane requirement goes down as altitude increases. That's why some places don't have 93-94 octane.
  6. #6 Re: Is there a 'safe' octane range for our engines?
    Kemmerer, Wyoming
    Quote Originally Posted by J57ltr View Post
    I don't think that is accurate, I think octane becomes more necessary as elevation decreased. More cylinder pressure at lower elevations
    I misread what you posted, we both said the same in opposite ways
  7. #7 Re: Is there a 'safe' octane range for our engines?
    GXP Level Member
    Mar 2015
    Tomball
    Yeah. This is why when you go to Denver or Utah they have 85,87,91 but you come to Houston or anywhere below 1000' or so they have 87,89,94.
    Jeff
  1. GTP AFR Range?
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2013, 10:23 PM
  2. What do low range mean???
    By Pierre in forum General Tech Discussion
    Last Post: 04-02-2013, 10:43 AM
  3. Safe to run 90 octane with 10% ethanol in my 3.8 N/A?
    By burgundybullet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2012, 04:25 PM
  4. New sub box...where'd my range go?
    By Sven the Sexman in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2012, 07:11 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
