Thread: Rough Acceleration
Results 1 to 12 of 12
  1. #1 Rough Acceleration
    Aug 2016
    Indiana
    '01 GTP bone stock with 120k on it. Accelerated rough under boost, but it was throwing a #3 injector code, a misfire code, and an O2 code. So I figured it was tied to the bad injector. Replaced the #3 injector and reset the ECU, all the codes cleared. The O2 code hasn't come back yet, but it's still accelerating really rough. I let it warm up and took it to some back country roads and gave it full throttle from a stop. Very rough acceleration, down on power, and it momentarily threw a #2 cylinder misfire code. It seems to be tied to the boost. Around 30-40% throttle with minimal boost it accelerates fine. It idles fine. The muffflers are off right now because I need to repair a weld in the exhaust piping but I don't think that's the problem. Any ideas?
  2. #2 Re: Rough accerleration
    Figure out what cylinder is still misfiring.
    Pull the plugs, maybe even just replace them. Inspect the wires and terminal ends on the coils, they could be causing it to run rough.
  3. #3 Re: Rough accerleration
    tune up time if its never been done before.
  4. #4 Re: Rough accerleration
    Aug 2016
    Indiana
    It does have new wires but I'll check the plugs.
  5. #5 Re: Rough accerleration
    Aug 2016
    Indiana
    #3 plug
  6. #6 Re: Rough accerleration
    Aug 2016
    Indiana
    I remembered, it has new plugs and wires
  7. #7 Re: Rough accerleration
    swap coils around see if it moves the misfire. you can also move the plug and the wire one by one, trying to make the misfire move.
  8. #8 Re: Rough accerleration
    Aug 2016
    Indiana
    Will do
  9. #9 Re: Rough accerleration
    Apr 2016
    New Jersey
    Check the white part of the plug(it's called porciline but I can"t spell it right), It may have carbon tracking on it. Carbon tracking looks hair line cracks, I had the same problem with mine. I switched to NGK TR6 plugs and new OEM wires and problems where solved.
  10. #10 Re: Rough accerleration
    GTP Level Member buickman104's Avatar
    NYC
    The plug in that picture doesn't look new at all. It looks as bad as my 15,000 mile plugs I changed out yesterday.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  11. #11 Re: Rough accerleration
    Aug 2016
    Indiana
    It ended up being a loose wire on the #2 plug. I'm planning on swapping them out for some colder ones in the near future anyway. Thanks for all the help!
  12. #12 Re: Rough accerleration
    Apr 2016
    New Jersey
    I'd recommend NGK TR6. They are working great for me so far!
  1. Really rough idling and choking on acceleration.
    By Flava601 in forum General Tech Discussion
    Last Post: 02-13-2012, 12:52 PM
  2. Rough Idle, Hessitation on acceleration
    By Dentcrew in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2012, 06:05 PM
  3. rough under heavy acceleration
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-03-2012, 02:20 AM
  4. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  5. Rough idle and acceleration
    By jokyfo in forum General Tech Discussion
    Last Post: 08-08-2010, 10:15 PM
