Thread: Power steering pump issue
Results 1 to 3 of 3
  1. #1 Power steering pump issue
    SE Level Member garret lamay's Avatar
    Mar 2015
    United States
    So I had one of the power steering pump bolts snap off in the block. Would it be easier to pull the engine so I can use a snapped bolt remover or to drop the subframe. I am thinking drop subframe cause I only need a couple inches to get to the hole. Next question how do I drop subframe using only floor Jack's and Jack stands cause that's all I have to use.
  2. #2 Re: Power steering pump issue
    id take the alt and its bracket off, then use a right angle drill on your extractor tool.
    cant ses lowering the frame being of any help.
  3. #3 Re: Power steering pump issue
    Mar 2015
    United States
    The problem is its the bolt on the bottom left near the oil fiter
  1. Power Steering Pump On Its Way Out
    By Danarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2012, 01:28 PM
  2. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
