Thread: Rough Idle, Hessitation on acceleration
Results 1 to 14 of 14
  1. #1 Rough Idle, Hessitation on acceleration
    Georgia
    Hi all, have a 97 GP 3.8 N/A that is idling very rough and hesitant while hitting the pedal. I've cleaned the PCV, IAC, MAF and EGR. I've unplugged the MAF sensor, but it runs the same while unplugged. It will die it you dump the gas pedal while parked if you have it above 1K RPM. Also, while idling I can slowely raise the RPM to 1000-1200 and try to maintain that RPM, but without letting the pedal up, it will drop back down to 800RPM. Then, if you dump the pedal, it dies, like being choked off. While idling, it will sound something like this.... hmmm chug chug chug chug hmmmm etc. Any suggestions?
    Ohio
    Overheating? Losing coolant? You may have blown out your uim
  3. #3 Re: Rough Idle, Hessitation on acceleration
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    check your coils could be a long shot but is easy and only takes 5 min (just pull the plugs see if they are rusty as hell)
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  4. #4 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Not over heating, not loosing coolant. Just went back out to see if I can describe it a little better. When you crank it, either warm or cold, it will idle perfect for a few moments at around 900-1000 RPM. Then on it's own, the idle will drop to around 650RPM and will do the hmmm chug chug chug hmmm think out the exhaust. When I make the pedal get to 1000-1200 and hold it steady there, it will quickly go back to 650RPM without relieving the pressure on the pedal. Now, when I completely let off the pedal, it will stall and die. But, when it I get it at WOT, and dump the pedal, it won't stall, but rather wind down to 900-1000RPM like it should for a moment, then drop to 650RPM again. It's almost as if the throttle is resetting itself when I slowly press and hold the gas pedal to get to around 1100-1300 RPM due to the drop back down to 650 on it's own, and when I dump the gas pedal, it dies as if it's not getting any gas.
  5. #5 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Just checked'em, there good.
  6. #6 Re: Rough Idle, Hessitation on acceleration
    SE Level Member aussie's Avatar
    Dec 2011
    Woodruff, SC
    Quote Originally Posted by Dentcrew View Post
    Check your fuel pressure...
    Then check your CAT
    1997 Grand Prix GT Coupe - Stock as a rock...
  7. #7 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Forgot to mention too, that the gas pedal sticks sometimes as well, like it's stuck. Takes a little pressue to "break free" and let go to accelerate. I checked at the linkage at the TB and same thing there as the pedal, so not the pedal assembly.
  8. #8 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Quote Originally Posted by aussie View Post
    Then check your CAT
    Ok, stupid question here...what's the "CAT"?
  9. #9 Re: Rough Idle, Hessitation on acceleration
    Dec 2011
    Woodruff, SC
    Catalytic Converter
  10. #10 Re: Rough Idle, Hessitation on acceleration
    Georgia
    DUH! Shoulda known that one. What the best way to check it, or what should I be looking for?
    Ohio
    Umm in some cases the cat will glow red if it's clogged enough. Just rev the car or drive it for a bit and get out and look under it
  12. #12 Re: Rough Idle, Hessitation on acceleration
    Clean your tb
  13. #13 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Do you guys think it could be the throttle position sensor? If so, is there a way to check? So far, I've ran the vehicle with the following unplugged, 1 at a time individually: MAF, IAC and TPS. There was no change in the crappy idling.
  14. #14 Re: Rough Idle, Hessitation on acceleration
    Georgia
    Reading other threads, and noticed someone swaping the ICM out and problem solved. It there a way to check the ICM for malfunctions b4 buying a new one to see?
  1. Really rough idling and choking on acceleration.
    By Flava601 in forum General Tech Discussion
    Last Post: 02-13-2012, 12:52 PM
  2. 98 Grand Prix GTP 3800 II, Troubleshooting Rough Idle and Sluggish Acceleration :(
    By 850Fishing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2012, 10:44 AM
  3. rough under heavy acceleration
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-03-2012, 02:20 AM
  4. engine idle rough, acceleration bad
    By ksredryder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2010, 08:30 AM
  5. Rough idle and acceleration
    By jokyfo in forum General Tech Discussion
    Last Post: 08-08-2010, 10:15 PM
